Mopar Differential For Sale - 4th Quarter #2826878
09/30/20 01:22 PM
09/30/20 01:22 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2827010
09/30/20 05:42 PM
09/30/20 05:42 PM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
8 3/4 center section-742 case-with 2.76 gears. This is an open center with a small yoke. Unit is complete and in good working condition. .Asking $150. Must be picked up in central jersey. Contact Bud Kramden426 at AOL.com
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2827013
09/30/20 05:48 PM
09/30/20 05:48 PM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
8 3/4 rear end housing for a 1971 thru 1974 B-body. Housing is bare and in good condition Asking $125. Contact Bud Kramden426 at AOL.com
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2827016
09/30/20 05:51 PM
09/30/20 05:51 PM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
1967 Dana 60, 3.54 gears, 602829 B.O.M. all new gaskets, seals, carrier and pinion bearings, 1350 pinion yoke, brake lines, tee and vent, most parts purchased from Dr. diff. New 11x2.5” brakes with original drums. Assembled, painted and ready to install. Professionally done. $3500/Firm. Located in Niagara Falls NY. Prefer local pickup,
Re: Mopar Differential For Sale - 4th Quarter [Re: Suregrip391] #2827521
10/01/20 06:31 PM
10/01/20 06:31 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
used original #2643008 casting,8 3/4 yolk, 7290 u joint(large), coarse pinion(742 ) , sandblasted,painted, nors pinion nut,washer&u joint strap&bolts. $60
cowgerwilliam035@gmail.com
742 001.JPG (699 downloads)
742 002.JPG (693 downloads)
742 003.JPG (695 downloads)
742 004.JPG (694 downloads)
Re: Mopar Differential For Sale - 4th Quarter [Re: Joesixpack] #2827523
10/01/20 06:36 PM
10/01/20 06:36 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
mopar RECONDITIONED original #54 072640 ARMASTEEL casting,8 3/4 yolk, 7260 u joint(small), fine pinion(489 ) , sandblasted,painted, nors pinion nut,washer&u joint strap&bolts. $50
WILL FIT 489 8 3/4 CENTERS WITH A FINE PINION
489A 003.JPG (695 downloads)
489A 004.JPG (693 downloads)
489A 001.JPG (697 downloads)
489A 002.JPG (694 downloads)
Re: Mopar Differential For Sale - 4th Quarter [Re: Joesixpack] #2827525
10/01/20 06:38 PM
10/01/20 06:38 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
MOPAR RECONDITIONED original #70 072640 ARMASTEEL casting,8 3/4 yolk, 7260 u joint(small), COARSE pinion(741&742 ) , sandblasted,painted, nors pinion nut,washer&u joint strap&bolts. $50
WILL FIT COARSE PINION EQUIPPED 741&742 8 3/4 CENTER SECTIONS WITH A SMALL 7260 U-JOINT
741C 001.JPG (692 downloads)
741C 002.JPG (695 downloads)
741C 003.JPG (692 downloads)
741C 004.JPG (690 downloads)
Re: Mopar Differential For Sale - 4th Quarter [Re: Joesixpack] #2827528
10/01/20 06:42 PM
10/01/20 06:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
MOPAR 8 3/4 DIFFERENTIAL CASE WITH &ADJUSTERS&LOCKS, &SNUBBER
BLASTED/PAINTED.
REPLACE THE BEARING RACES, GIVE IT A FINAL CLEAN AND YOUR READY TO ADD YOUR RING&PINION&SURE GRIP$175
8 34 002.JPG (689 downloads)
8 34 004.JPG (690 downloads)
8 34 012.JPG (691 downloads)
8 34 009.JPG (690 downloads)
8 ¾ Sure Grip Center 3.23 Gears & 489 Case - Re [Re: Joesixpack] #2828305
10/03/20 02:14 PM
10/03/20 02:14 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a rebuilt 8 ¾ sure grip center section with all new Timken bearings, races, seals, shims and some new hardware. A crush sleeve eliminator kit was used to replace the crush sleeve with a solid spacer and shims. All parts purchased through Doctor Diff. Gear set is nice with no chipped teeth, rust or pitting. Large yoke is installed. Not run or installed since rebuild.
Price is $900 plus shipping. Local pickup in CT is welcome.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2829453
10/06/20 06:14 PM
10/06/20 06:14 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
I have a pair of used Strange Engineering Hy-Tuff 35 spline axles, excellent condition. These came out of a friend's bracket car. They have 1/2 inch screw in studs (3 inch long), & bearings. One axle measures 22 1/2 inches from the back side of the retainer plate to the end of the splines, the other measures 23 1/2 inches. The splines are 3 1/4 long. Asking $275.00 for the pair plus actual shipping..
PM me here (1st choice), or e-mail me at duster doug at comcast dot net..
Thanks for the ad Moparts!!!
"I've upped my horsepower, so...... UP YOURS!!!"
742 case with 2:76 gear [Re: DusterDog] #2830309
10/08/20 11:18 AM
10/08/20 11:18 AM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
Nice condition 742 case with open 2:76 gear - appears to be dated 4-29-68
$100.00
MUST PICK UP IN NW INDIANA - 1hr outside Chicago
PM here on the board
FE5 Challenger T/A
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2831379
10/10/20 11:21 PM
10/10/20 11:21 PM
Colorado Springs
TA_Care Offline
TA_Care  Offline
Colorado Springs
10" 4,000 stall PTC Torque Converter for 727 This is a GREAT unit! It DID stall 4,000 rpm on my 340 Six Pak Challenger. It was 99% street driven for 2,000 miles WITH a large trans cooler (never overheated). $500 plus shipping (approx $30-$50 UPS Ground). Ready to go!
Serious inquiries only. Venmo, Cashier's Check. tuhalt@gmail.com
[Linked Image] [Linked Image] [Linked Image] [Linked Image]
PTC 10 inch-M.JPG (497 downloads)
4,000 stall PTC 10" torque converter w/drain plug for 727
PTC 10 inch in box-M.JPG (497 downloads)
4,000 stall PTC torque converter in box
PTC 10 inch Part No-M.JPG (497 downloads)
PTC box and part number #PTC 9.5-TF-8
PTC 10 inch box-M.JPG (496 downloads)
4,000 stall 10" PTC torque converter in box ready to send to YOU!
Re: Mopar Differential For Sale - 4th Quarter [Re: TA_Care] #2834024
10/17/20 08:37 PM
10/17/20 08:37 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
I have a pair of 1968 1969 1970 B Body axles for sale.
The old used stock bearings have been removed and new green bearings pressed on.
The length from the end of the splines to the outside lip of the flange is 29 3/16"
These are the 30 spline axles for an 8 3/4 rear end.
I found the set of 10 long wheel studs that go with these and are included.
I assembled these for my 1970 GTX bracket car and never used them when I went to a DANA!
The price is $225.00 plus shipping.
If interested contact me at: moparjohn@frontier.com with your zip.
Thanks! John
1970 489 Case 8 3/4 Housing [Re: moparts] #2834434
10/19/20 05:00 AM
10/19/20 05:00 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
8 3/4 Housing 489 case for rebuilding. No guts just the housing. I believe it is from a 70 car. Has 7260 yoke size.
$125 plus shipping
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
Re: Mopar Differential For Sale - 4th Quarter [Re: moparts] #2837193
10/25/20 09:02 AM
10/25/20 09:02 AM
gtxblu Offline
gtxblu  Offline
I have a 8 3/4 489 case detroit locker sure grip with 3,91 gear center section. The unit might have 50 miles on it at best. I went a different direction on my car so this unit is for sale. I has $1200 in the build. It has the small yoke but I did purchase a large yoke from mancinis. Asking $900.00. 1-734-775-0738. located outside of detroit.
Re: Mopar Differential For Sale - 4th Quarter [Re: gtxblu] #2837620
10/26/20 03:43 PM
10/26/20 03:43 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
8 3/4 used pinion snubber, an older home made version, 2 sets of adjustment holes, perfect for a rat rod or a road kill project, or a cheap bracket car...$40 mailed insured/tracked priority mail medium flat rate box.
cheap 001.JPG (81 downloads)
cheap 002.JPG (81 downloads)
cheap 003.JPG (81 downloads)
cheap 004.JPG (81 downloads)
