Water pump id #2833620
10/16/20 07:55 PM
10/16/20 07:55 PM
Omaha
road Offline OP
road  Offline OP
Omaha
What is it?
Attached are two pics of a water pump set up.
The casting number on the housing is 1671895. Above it is the number 4. following that like a tag is a PF. There are also other letters and numbers.
On the impeller piece is the casting PH 154
Re: Water pump id [Re: road] #2833725
10/17/20 01:43 AM
10/17/20 01:43 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Kind of looks like an industrial or truck application.
Re: Water pump id [Re: road] #2833855
10/17/20 01:10 PM
10/17/20 01:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
The housing looks like a Chevy but the pump doesn't, it looks like BB Mopars confused
Re: Water pump id [Re: Cab_Burge] #2833864
10/17/20 01:27 PM
10/17/20 01:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
BB WP housings have two holes on each side.
Re: Water pump id [Re: Cab_Burge] #2833884
10/17/20 02:10 PM
10/17/20 02:10 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Pump is not bb mopar. Too many bolt holes.
Re: Water pump id [Re: John_Kunkel] #2833889
10/17/20 02:22 PM
10/17/20 02:22 PM
moparx Offline
moparx  Offline
i have pics somewhere, [but maybe not on this 'puter] but i just looked on the shelf to confirm my memory.
i believe that housing could be a 392 hemi. they have the single hole inlets to the heads, and the single large upright [not the heater hose barb] barb is a bypass to the intake manifold.
what size diameter is the water pump housing ? the hemi pump diameter is larger than a big block pump, which is roughly 5" [ish].
a front side pic of the housing, along with some measurements [like bolt hole center to center, etc.] will confirm my suspicions.
beer
edit : the casting numbers on the housing do not match anything i have on the early hemi, however. this still doesn't mean that housing is not for an early hemi. measurements will help.
another thing. the early hemi also has 4 attaching bolts for the water pump like the big block, so now i just don't know what to think.......... shruggy
Re: Water pump id [Re: moparx] #2833919
10/17/20 03:41 PM
10/17/20 03:41 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Appears to `69-`73 Dodge M300 motor home with big block engine , w/p p/n 3420225 with 5/8" pilot. Paul
