Firecore vs. FBO
#2833328
10/16/20 09:51 AM
10/16/20 09:51 AM
Posts: 46 Medford, OR
carrman
Medford, OR
Looking at buying a new distributor for the 440 in the Newport. Currently running the MP electronic and having some issues with too much advance under vacuum. I know that's adjustable but after reading up on these it sounds like they have issues with jumpy timing and such. So, what are the differences between the Firecore and the FBO billet distributors? Besides 100 bucks that is if I don't have Don tailor make a curve for a new one...... Will the Mallory adjuster kits work in either of these dizzys? https://www.summitracing.com/parts/sum-850535-1
Re: Firecore vs. FBO
[Re: Cab_Burge]
#2833702
10/16/20 11:49 PM
10/16/20 11:49 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
I've been using this deal from Progression Ignition. Very happy with it, you can change curve tables in seconds. Idles and starts cleaner, and smoother all around than the old MP unit it replaced. I feel better no one can start the car when it's off on security lock You ditch the module and ballast, uses a full 12v https://progressionignition.com/
[Re: 65Fury440]
#2833720
10/17/20 12:55 AM
10/17/20 12:55 AM
Posts: 1,169 MI
68shifter
MI
I’ve been using Firecores, both bb and sb, in street cars for 4 or so years now, no issues. Much better than the MP piece I had in the BB, and the SB stuff I ditched an FBO setup that was in the car when I bought it-just had some weird issues.
Odd though, the Firecore site now only lists the sb from what I could see.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: Dragula]
#2833861
10/17/20 01:19 PM
10/17/20 01:19 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
MSD race units like the early 404 and the 7 race boxes of all types require a coil that has a lot different windings inside the coil, I don't remember exactly if the stock coils are 400 to 1 and the MSD coil need 200 to 1 or vice a versa I like the early Mallory #28880 or the same coil with the MSD sticker on them The later small red MSD coil for their race boxes work well also
[Re: Cab_Burge]
#2834047
10/17/20 09:37 PM
10/17/20 09:37 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have one of the first run of Firecore distributors, I think is was the first one Rick ever sold Been trouble free since the day I installed it with a set of FC wires. I run it with a 6AL and an MSD blaster SS coil . Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 65Fury440]
#2839285
10/30/20 01:17 PM
10/30/20 01:17 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I've been using this deal from Progression Ignition. Very happy with it, you can change curve tables in seconds. Idles and starts cleaner, and smoother all around than the old MP unit it replaced. I feel better no one can start the car when it's off on security lock You ditch the module and ballast, uses a full 12v https://progressionignition.com/ I'm thinking really hard about picking one of those up.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 65Fury440]
#2839785
10/31/20 03:23 PM
10/31/20 03:23 PM
Posts: 3,208 Md.
carnut68
Md.
I've been using this deal from Progression Ignition. Very happy with it, you can change curve tables in seconds. Idles and starts cleaner, and smoother all around than the old MP unit it replaced. I feel better no one can start the car when it's off on security lock You ditch the module and ballast, uses a full 12v https://progressionignition.com/ Might just be the answer I need instead of a locking out dist. Which I have avoided doing.
America First!
