Engine run in stand #2833052
10/15/20 02:25 PM
10/15/20 02:25 PM
MN
JERICOGTX Offline OP
MN
Anyone here ever built there own engine run in stand? Would be nice to run an engine to test for leaks, or break in a cam before wasting dyno time. post pictures if you have done this.
Thanks.
69 GTX 68 Road Runner
Re: Engine run in stand [Re: JERICOGTX] #2833064
10/15/20 03:15 PM
10/15/20 03:15 PM
an8sec70cuda Offline
Yep, built one years ago out of old scrap laying in the dirt by the barn, lol. It's crude as he11, but works great and has had a bunch of different engines on it.
Uses an old cast iron 4 speed bellhousing and flywheel I had laying around. Standard motor mounts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine run in stand [Re: an8sec70cuda] #2833076
10/15/20 03:53 PM
10/15/20 03:53 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Made out off some chanel that was laying around. Definitely over kill.[Linked Image][Linked Image][Linked Image][Linked Image]
Re: Engine run in stand [Re: an8sec70cuda] #2833092
10/15/20 04:51 PM
10/15/20 04:51 PM
NC
440Jim Offline
440Jim  Offline
NC
CHIP,
Do you have a picture of how you supported the rear of the bellhousing?
Re: Engine run in stand [Re: OUTLAWSSAA] #2833094
10/15/20 04:53 PM
10/15/20 04:53 PM
NC
440Jim Offline
440Jim  Offline
NC
Outlaw,
What guts do you have in the trans?
Do you have trans fluid in it?
Re: Engine run in stand [Re: JERICOGTX] #2833099
10/15/20 05:10 PM
10/15/20 05:10 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Built one 10 years ago, been used dozens of times. You will like having one.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Engine run in stand [Re: BANDIT] #2833100
10/15/20 05:13 PM
10/15/20 05:13 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Rear shot.
4600 DA
Re: Engine run in stand [Re: JERICOGTX] #2833122
10/15/20 07:05 PM
10/15/20 07:05 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks.
I have always wanted one and even bought a bell housing and flywheel as a start.
However when I heard Total Seal say that a new engine should be run without a load as little as possible with new rings, it cooled my enthusiasm.
Re: Engine run in stand [Re: 340Cuda] #2833153
10/15/20 08:44 PM
10/15/20 08:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have one 80% finished. If you lived closer I would sell you mine. Mine is set up to use a Chevy flywheel from a powerglide to Mopar Kit and a starter adapter I bought from a Moparts member that made and sold them
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine run in stand [Re: 340Cuda] #2833185
10/15/20 09:55 PM
10/15/20 09:55 PM
Thanks.
I've heard just the opposite about breaking in a new motor and ring seating and proper ring seal.
I've seen more new engines use oil for awhile that where broken in the car for 20 to 45 minutes with no load than I've seen and owned motors broken in on a engine dyno or out on the road broken in under driven loads breaking in the cam up scope
Re: Engine run in stand [Re: an8sec70cuda] #2833203
10/15/20 10:37 PM
10/15/20 10:37 PM
MN
MN
Here is what I have so far. Got some tubing drops from work. I found the transmission mounting locations for GM, Ford, and Mopar 4 speeds, so any bellhousing will fit. The front motor mounts are removable, and I’ll make different ones that I think will get used. Need to figure out a battery mount location, and what to do for fuel yet.
110EE87B-B6D9-43C5-B64F-86EF3BEDEE27.jpeg0BA2C0A1-592A-4FA5-ADC6-DB077AB1C305.jpeg390BC748-39BB-43C2-A800-26E229F816C2.jpeg
Re: Engine run in stand [Re: JERICOGTX] #2833265
10/16/20 06:09 AM
10/16/20 06:09 AM
tboomer Offline
tboomer  Offline
It's a good start Jeff! wave
Re: Engine run in stand [Re: JERICOGTX] #2833310
10/16/20 09:05 AM
10/16/20 09:05 AM
montana
BANDIT Offline
BANDIT  Offline
montana
You might rethink your radiator mount, especially if you ever haul the thing around. Mine moved around enough to cause radiator damage to one of the tanks. I have since switched to the cradle stock type setup. My fuel cell, pump, and battery are below the radiator and a little forward. With gauges and ignition above them, it makes it somewhat compact. You have a good start there. Jim.
4600 DA
Re: Engine run in stand [Re: tboomer] #2833316
10/16/20 09:10 AM
10/16/20 09:10 AM
PA.
"Little"John
"Little"John
PA.
Heck yaa. You will be making noise in no time
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Engine run in stand [Re: BANDIT] #2833318
10/16/20 09:16 AM
10/16/20 09:16 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If this will be used in the same space you store you car I would just make a long fuel line and utilize the fuel system from your car.
68 Barracuda Formula S 340
Re: Engine run in stand [Re: Bad340fish] #2833323
10/16/20 09:35 AM
10/16/20 09:35 AM
MN
MN
I want it to be a self contained unit, so any of my friends locally can use it. HEMI Joel has a complete set of gauges for me, and another friend is donating an older electric fuel pump he doesn’t need. I’m thinking of an aluminum 2 gallon cell, as they are cheap on eBay. I have an old Holley regulator in the trailer, so I think I just need to find a dirt cheap MSD 6A, and a coil.
Re: Engine run in stand [Re: JERICOGTX] #2833350
10/16/20 10:21 AM
10/16/20 10:21 AM
NC
440Jim Offline
440Jim  Offline
NC
Jeff,
What distance between the headers did you use? (yellow arrows)
What car do those headers fit?
Re: Engine run in stand [Re: 440Jim] #2833592
10/16/20 06:08 PM
10/16/20 06:08 PM
MN
MN
Originally Posted by 440Jim
Jeff,
16 inches. The headers are my old Hooker 5209’s that fit my Road Runner. They are just hanging from the block. If I bolted them to a cylinder head, they would be tipped out at the bottom, quite a bit more.
Re: Engine run in stand [Re: Cab_Burge] #2833755
10/17/20 08:15 AM
10/17/20 08:15 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thanks.
That might apply to older style ring packs maybe? The new thin and light stuff may be different. Total seal probably has a decent idea of what they are talking about? grin
Re: Engine run in stand [Re: Cab_Burge] #2833778
10/17/20 09:30 AM
10/17/20 09:30 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks.
I read an article from a guy who built and raced cycles. He built two identical engines. One went through a normal break in period then raced for a season. The other raced right out the box full blast. The second always ran faster and at end of season after tear down looked like new, first one had carboned up rings-crankcase and weird wear in the cylinders. He figured the immediate pressure seated the rings better. The old addage on running it hard off the showroom floor proved true.
