Page 1 of 3 1 2 3
Mechanical Roller lifter suggestions. #2832963
10/15/20 10:49 AM
10/15/20 10:49 AM
Tucson,AZ
Remow2112 Offline OP
Tucson,AZ
Hi all,
Done a ton of searching on here and had mixed results. I would like to go roller on my new 400 build (.30 over, kb240 pistons, 5 in the hole). I would like lifters that direct oil the wheel, I saw Andy used the AMC from Comp Cams but they no longer makes those. I have searched tons of websites and rarely does it state if the lifter direct oils the wheel. Plan on using Lunati 40230730 cam.
So what lifters should I get or suggestions?
Thanks!
Re: Mechanical Roller lifter suggestions. [Re: Remow2112] #2832997
10/15/20 12:24 PM
10/15/20 12:24 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I run the Isky Red Zone bushed mechanical rollers. I attached a cut-away photo. I believe there is some info floating on the web that they actually don't directly oil the bushing though. So far, my valve lash is very stable and my valve train is the smoothest running it has ever been. I did use B3 racing spec'd custom T&D rocker arm set-up and Manton Stage 5 7/16's pushrods.
Another thing that i did was install a collar on the distributor shaft to limit the up and down movement of the intermediate shaft gear(it dramatically reduced wear on my previous bronze gears), which is a hardened steel unit from Hughes Engines.
Re: Mechanical Roller lifter suggestions. [Re: jbc426] #2833013
10/15/20 12:52 PM
10/15/20 12:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What is that passageway inside the red circle?
Looks like an oiling passageway to me?
Re: Mechanical Roller lifter suggestions. [Re: Sniper] #2833120
10/15/20 07:00 PM
10/15/20 07:00 PM
MN
W
Willie68coronet Offline
W
MN
I have comp 96829-16 lifters in my 440. They have the same height pushrod seat as the regular comp 829 lifters but have the orifice to oil the needle bearings and are made of stronger material. They also have a bushed version of my lifters with no needle bearings which are 96829b-16
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Mechanical Roller lifter suggestions. [Re: Willie68coronet] #2833189
10/15/20 10:00 PM
10/15/20 10:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Crane 66550-16 I bought mine from a member on here. competitionwedge I believe.
A few years ago at the Indy Cylinder Heads Mopar show I asked the Comp Cams guy what he thought of the bronze bushings instead of bearings in the rollers. His opinion was "race only - absolutely not for street use".
To your point about directing oil to the roller ... many brands advertise "pressurized roller oiling" for a specific style lifter but when you ask point blank "do the Mopar lifters have pressurized oiling" the answer will be "no". Do your homework. The Crane's do have pressurized oiling and also have the rollers shrouded to prevent uncovering the oil galley at high lift (not an issue with your itty-bitty cam).
Re: Mechanical Roller lifter suggestions. [Re: Remow2112] #2833206
10/15/20 10:47 PM
10/15/20 10:47 PM
AndyF Offline
AndyF  Offline
Originally Posted by Remow2112
Hi all,
Thanks!
They still make them. Just got a set last week.
Re: Mechanical Roller lifter suggestions. [Re: AndyF] #2833238
10/16/20 01:52 AM
10/16/20 01:52 AM
Tucson,AZ
Tucson,AZ
Thanks for all the info.
Andy,
I have scoured their website and they appear to not exist. Can you share the part number or where you got them from?
Dan...
Re: Mechanical Roller lifter suggestions. [Re: Sniper] #2833397
10/16/20 11:25 AM
10/16/20 11:25 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes, this picture definitely shows a direct pressure oil passage. As to if this guarantees that the Mopar set has this feature remains unclear to me. AndyF uses the AMC solid rollers for a reason, which I believe is related to the location of the pushrod seat and the shrouding of the lifter to prevent uncovering of the oil galley in high lift cam use. I could be wrong, but AndyF's knowledge of these lifters is from first hand, skilled machinist knowledge.
Notice Stanton points out the issue very well in his post. "To your point about directing oil to the roller ... many brands advertise "pressurized roller oiling" for a specific style lifter but when you ask point blank "do the Mopar lifters have pressurized oiling" the answer will be "no". Do your homework. The Crane's do have pressurized oiling and also have the rollers shrouded to prevent uncovering the oil galley at high lift (not an issue with your itty-bitty cam)."
Re: Mechanical Roller lifter suggestions. [Re: Remow2112] #2833429
10/16/20 12:05 PM
10/16/20 12:05 PM
AndyF Offline
AndyF  Offline
Andy,
Dan...
Call Comp Cams and tell them that you want AMC solid roller lifters with Chrysler big block tie bars so you can use them in a big block Mopar.
Re: Mechanical Roller lifter suggestions. [Re: Remow2112] #2833701
10/16/20 11:46 PM
10/16/20 11:46 PM
For long life on the street with high RPM, above 7000 RPM, buy the best lifters you can get your hands on, regardless of the price twocents
I like and use the Crower brand BB Mopar roller lifters now up scope Contact them at 619-661-6477 8:00 AM to 5:30 PM Pacific time
Re: Mechanical Roller lifter suggestions. [Re: AndyF] #2833743
10/17/20 07:02 AM
10/17/20 07:02 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by AndyF
Call Comp Cams...................
WHAT?!?!?!
Re: Mechanical Roller lifter suggestions. [Re: Remow2112] #2833766
10/17/20 08:55 AM
10/17/20 08:55 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Engine Masters just had an episode on lifters. The focus was hydraulic vs roller, but at the end of the episode, Dulcich and Ehrinburg have a discussion about the different styles of lifters available. They really felt that while there were big differences in lifter quality between brands, there was not a clear winner as to which style was the 'go-to' one. All types had their strengths and weaknesses. Interesting stuff.
Master, again and still
Re: Mechanical Roller lifter suggestions. [Re: DaveRS23] #2833787
10/17/20 10:10 AM
10/17/20 10:10 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
JBC, where did you source the collar shown in your post/
I have the collar from Hughs and it's the type you have to put a set screw into the shaft to tighten.
Your shows a cinching type which I believe will be easier to install.
Hughs shows in their catalogue the set screw type.
Thanks. Joe
Re: Mechanical Roller lifter suggestions. [Re: jlatessa] #2833848
10/17/20 12:44 PM
10/17/20 12:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Thanks. Joe
I believe Hughes Engines used to carry the style I have pictured, but here's a link to another source.
https://www.huyett.com/products/power-transmission/shaft-collars/single-split-shaft-collars
I do clean the locking screw and collar with brake/carb cleaner, let it dry and use loctite on the screw. In addition to stabilizing my timing the collars significantly reduced the wear on my intermediate shaft gears.
I used to run bronze, but have since switched to the coated steel gears available at Hughes. I used to wondered how much having the bronze gear cryogenically treated would help, but when I switched to a new solid roller cam , I went with the steel gear.
Re: Mechanical Roller lifter suggestions. [Re: jbc426] #2833922
10/17/20 03:54 PM
10/17/20 03:54 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
JBC, do you remember off-hand what the diameter of the dist. shaft is?
Thanks, Joe
Re: Mechanical Roller lifter suggestions. [Re: jlatessa] #2834010
10/17/20 08:12 PM
10/17/20 08:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think it is 1/2"
McMaster-Carr
https://www.mcmaster.com/shaft-collars/construction~one-piece/clamping-shaft-collars-9/
Re: Mechanical Roller lifter suggestions. [Re: BSB67] #2834015
10/17/20 08:28 PM
10/17/20 08:28 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Thanks guys....Joe
Re: Mechanical Roller lifter suggestions. [Re: jlatessa] #2834031
10/17/20 08:47 PM
10/17/20 08:47 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Only use Comp Cams if you don't care if you motor blows on the dyno and your one that pulls hundred dollar bills out of your butt. Their lifters and rockers are JUNK.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Mechanical Roller lifter suggestions. [Re: moparmarks] #2834229
10/18/20 02:07 PM
10/18/20 02:07 PM
AndyF Offline
AndyF  Offline
I've used Comp Cam cams, lifters and rocker arms for years without any issues.
Re: Mechanical Roller lifter suggestions. [Re: AndyF] #2834251
10/18/20 03:12 PM
10/18/20 03:12 PM
moparmarks Offline
moparmarks  Offline
Years ago Comp was pretty good stuff but the last few years they have gone to crap. Have had several failures with their roller rockers and roller lifters on different motors Mopar, Ford and Chevy. A few were on the motor dyno before the motors ever saw a car.
Their customer service is worse than Indy Cylinder Head.
Here more about them
https://www.forbbodiesonly.com/mopa...camshaft-ever-seen-one-like-this.203738/
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Page 1 of 3 1 2 3
