HOT ROD/RAT ROD RADIO FLYER #2833004
10/15/20 12:34 PM
10/15/20 12:34 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I'll start out by saying I'm in my early 40s, have loved cars all my life but have never learned how to weld. I got tired of asking others for help so I picked up a small Titanium flux core from Harbor Freight. Before you immediately start laughing, I didn't want to buy an expensive unit just to try my hand at welding. A friend had gotten a Chicago Electric welder as a gift and let me try it out last year. It didn't go well. The Titanium had some good reviews so I thought it would be an OK welder to try and practice with. I have no intensions of trying to weld sheet metal or critical components with it. I just needed something for really small jobs that might pop up from time to time. So far it's been a night and day difference between the Titanium and the Chicago Electric. Now with that out of the way, I thought I'd share my first welding project.
I don't want to get into an argument about what you want to call it...Hot Rod or Rat Rod...whatever. I saw a picture of a really cool looking old Radio Flyer that someone had modified. I googled "rat rod radio flyer" and saw a lot of really cool wagons and got some good ideas. Back when I turned 1, my grandparents bought me a brand new Radio Flyer wagon. My sister, brother and I used it a lot throughout our childhood. My parents still had it up in their attic. It was just sitting there so I thought, "why not". Might as well make something cool with it.
There were a couple long pieces of 1.5"x1.5" square tubing in my shed that had been left by a previous owner. This was the perfect time to put those to use. I came up with a simple frame design from pictures I saw online. After cutting out all the pieces and beveling the edges, I welded them together. Overall it went pretty good for my first time I think. I did learn a lot about how much metal can move around while welding.
Here is the completed frame. I had some old pitted E-body front spring hangers laying around. They looked like the perfect thing to use as a steering knuckle/spindle.
Here is the frame with the wheels mocked up. I also made some "headers" that bolt to the frame and just barely stick out past the wagon tub.
I made the steering linkage with some heim joints and 1/2" aluminum round stock. I really wasn't liking the overall look at this point. It needed something extra to really set it off. The original 318 from my 68 Dart was sitting in the corner and I got an idea. I made up a small mounting plate and mounted the 2-barrel carb to the frame. That's exactly what it needed. It really changed the look of it IMO.
Re: HOT ROD/RAT ROD RADIO FLYER [Re: burdar] #2833006
10/15/20 12:38 PM
10/15/20 12:38 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
This is the basic design all mocked up. I still needed to disassemble everything to paint the frame and wheels. There was a large gap between the frame and the steering knuckles. I ended up using some junk valve springs as spacers in that location. They kind of look like little coil springs in there now.
So, I let it sit for a few months but just got back around to finishing it. I painted the wheels and the "white walls" on the tires. I extended the handle arm 14" so I didn't have to bend down so low to pull it. I also added a Hurst shifter handle to the handle arm to finish it off. We took it out for a test run last night. My 3 year old loved it. She had a big smile on her face. That's what it's all about after all right? So here it is, my first welding project is done. What do you think? In typical Mopar fashion, no part of the original wagon was modified. Someone can return it to stock one day if they really want to.
Re: HOT ROD/RAT ROD RADIO FLYER [Re: burdar] #2833009
10/15/20 12:43 PM
10/15/20 12:43 PM
tboomer Offline
tboomer  Offline
Now that's pretty cool Darren! Nice job!
Re: HOT ROD/RAT ROD RADIO FLYER [Re: tboomer] #2833044
10/15/20 02:02 PM
10/15/20 02:02 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Cool, and a real cutie there as well !
Re: HOT ROD/RAT ROD RADIO FLYER [Re: tboomer] #2833045
10/15/20 02:03 PM
10/15/20 02:03 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Cooler than the other side of the pillow - well done
Re: HOT ROD/RAT ROD RADIO FLYER [Re: burdar] #2833050
10/15/20 02:13 PM
10/15/20 02:13 PM
SK. Canada
Not_A_Duster Offline
SK. Canada
....evil is winning....
Re: HOT ROD/RAT ROD RADIO FLYER [Re: Not_A_Duster] #2833062
10/15/20 03:11 PM
10/15/20 03:11 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
nice work
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: HOT ROD/RAT ROD RADIO FLYER [Re: bigdad] #2833074
10/15/20 03:46 PM
10/15/20 03:46 PM
Rocky Hill, Ct
Roadcuda Offline
Roadcuda  Offline
Rocky Hill, Ct
I like it, nice work!
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
Re: HOT ROD/RAT ROD RADIO FLYER [Re: Roadcuda] #2833105
10/15/20 05:52 PM
10/15/20 05:52 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
You did real well with that,came out great.Your metal skills are outstanding.
Re: HOT ROD/RAT ROD RADIO FLYER [Re: 5carguy] #2833134
10/15/20 07:46 PM
10/15/20 07:46 PM
Guitar Jones Offline
Yep. Really nice.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: HOT ROD/RAT ROD RADIO FLYER [Re: Guitar Jones] #2833165
10/15/20 09:16 PM
10/15/20 09:16 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You did a really good job with the flex core wire. If you invest in the gas kit and it as a Mig, you will do a lot less grinding.The gas makes it a bit easier to use as well. Gene
Re: HOT ROD/RAT ROD RADIO FLYER [Re: burdar] #2833194
10/15/20 10:08 PM
10/15/20 10:08 PM
Medford OR
FrankenScamp Offline
Medford OR
Sooooooo cool!
thumbs thumbs
Re: HOT ROD/RAT ROD RADIO FLYER [Re: FrankenScamp] #2833262
10/16/20 05:49 AM
10/16/20 05:49 AM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
That is awesome. up
Only thing I'd say is you probably ought to remove the carb stud or get some cool small air cleaner to cover it up, before someone gets hurt on that open stud sticking up.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: HOT ROD/RAT ROD RADIO FLYER [Re: adventurer] #2833294
10/16/20 08:24 AM
10/16/20 08:24 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Originally Posted by adventurer
That is awesome. up
Yeah that thing is just begging for a cool little mini-chrome air cleaner to top it off...
We must be near the same age because my brother and I had a wagon exactly of that era--graphics and everything. Ours is long gone, though. Rusted out and beat to hell and back from racing it down the hill across the street from our house.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: HOT ROD/RAT ROD RADIO FLYER [Re: wingman] #2833330
10/16/20 09:55 AM
10/16/20 09:55 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Quote
Quote
up That's the plan. With everything going on this year though, there were no swap meets to look for a small air cleaner. If I can't find something I like, I'll try and make something that looks cool. I'm thinking about putting a small license plate on the back. I think I have a couple of those small trailer plates somewhere.
Re: HOT ROD/RAT ROD RADIO FLYER [Re: burdar] #2833365
10/16/20 10:50 AM
10/16/20 10:50 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
came out great
Re: HOT ROD/RAT ROD RADIO FLYER [Re: DusterKid] #2833435
10/16/20 12:13 PM
10/16/20 12:13 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Very creative.... up
Thanks for sharing ...
Re: HOT ROD/RAT ROD RADIO FLYER [Re: mccannix] #2833847
10/17/20 12:43 PM
10/17/20 12:43 PM
moparx Offline
moparx  Offline
very well done ! bow
this now becomes a true family heirloom.
beer
