Re: Power source for wiring an elec fuel pump
[Re: Belvedere1]
#2831127
10/10/20 12:41 PM
10/10/20 12:41 PM
Posts: 11,494 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pump in the rear? Battery in the rear?
Use a relay. Run the relay with the switch. Run the high amp line from a good power source - direct from the battery if it is in the trunk. Wire size is dependent on the pump. If it needs to run from the front to the back of the car, it needs to go up a few sizes from what you think you need.
Switch/pump should only be hot in IGN ON, not constant. Pump should quit when the ignition is turned off.
Stock systems don't work well for adding stuff. The BAT+ stud on the starter relay is probably the safest source.
[Re: Belvedere1]
#2832953
10/15/20 10:21 AM
10/15/20 10:21 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The pump will be near the stock tank, battery is up front. The pump is a small low amp setup, less than 10 amps. For sure on a switched "key on" source. I guess that is my main question is to where to draw the key on power source from. Without going directly from the positive side of the battery terminal what is the next best place to pull from? 8 to 9 amps is still alot for the stock system in particular because the pump probably should be running during start and then of course in run. If you really want to do this my suggestion is use a relay. Trigger the relay with the ignition 1 (run) wire. Piggy back terminal at the ballast resistor is probably the best and will be reversible (no cutting needed). Get power to the relay for the pump by connecting to the alternator output stud. Use a fuse on this line. Size the fuse for the pump or wire size, whichever is smaller. Connecting at ignition 1 means power from ignition 2 (start) will trigger the relay on during starting. If the relay trigger demand is low (less than an amp) there will be very little drop in voltage though the ballast resistor. Drawing power for the pump from the alternator means the ammeter will still read correctly and also avoids putting a constant current through that extra distance, extra connections, and the fusible link.
[Re: Belvedere1]
#2833089
10/15/20 04:46 PM
10/15/20 04:46 PM
Posts: 4,205 New York
polyspheric
New York
Think about a mercury switch to kill the power if the car stops upside-down etc.
Boffin Emeritus
[Re: Mattax]
#2833218
10/15/20 11:41 PM
10/15/20 11:41 PM
Posts: 1,261 Phoenix, AZ
Belvedere1
Phoenix, AZ
OK, I see the point of the relay so now I am trying to understand where the oil pressure switch would wire into a relay setup. Would you happen to have a diagram? I'll assume the relay would physically be near the oil pressure switch somewhere on the firewall and not near the fuel pump. After looking into the relay more it looks like a relay kit from Ron Francis would simplify this quite a bit. I'm still not finding much on where in the circuit the dash toggle switch would go.
[Re: Belvedere1]
#2833246
10/16/20 03:35 AM
10/16/20 03:35 AM
Posts: 2,070 CA
crackedback
CA
OK, I see the point of the relay so now I am trying to understand where the oil pressure switch would wire into a relay setup. Would you happen to have a diagram? I'll assume the relay would physically be near the oil pressure switch somewhere on the firewall and not near the fuel pump. After looking into the relay more it looks like a relay kit from Ron Francis would simplify this quite a bit. I'm still not finding much on where in the circuit the dash toggle switch would go. toggle switch to oil pressure switch then to fuel pump relay trigger terminal Personally, I like the relay close to whatever it is powering. Makes troubleshooting a bunch easier. All you need is the trigger wire and a fused power wire to the rear of car. Pretty simple to do.
[Re: Belvedere1]
#2833604
10/16/20 07:03 PM
10/16/20 07:03 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Maybe this will help you as it helped me. I saw the article sometime in the '90s, I think this is rehash, but whatever.... https://www.hotrod.com/articles/safe-and-efficient-electric-fuel-pump-wiring/This plan has worked for me for alot of years, it's cool but it is lacking one thing--A way to manually fill bowls when they are empty. Using this setup the pump will kick on when oil pressure is developed during cranking, but myself I like to have the bowls already full before then. So I changed it a little bit to allow me to do that easily from underhood, which is handy when making changes to the carb that require the bowl to be pulled, or if it has sat for a long time.
Rich H.
Esse Quam Videri
[Re: crackedback]
#2834385
10/18/20 10:33 PM
10/18/20 10:33 PM
Belvedere1
Phoenix, AZ
So it looks like the only way to run this how I would like is to have 2 toggle switches as stated using a relay. I also had another opinion from someone who thinks I am way overthinking this whole thing with only wanting to use the electric pump for priming the carb after months of sitting and a few times a year with some spirited driving or a pass or two at the strip. I really have no intention of running the electric pump 98% of the time for normal driving.
Thanks for that link Zippy and appreciate the help from the others.
