B to RB intake adapters #2831932
10/12/20 02:11 PM
10/12/20 02:11 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Anyone know where to locate a set of B to RB intake manifold spacer adapters?
I have a M1 tunnel ram that I really would like to use on the 440.
Since the M1 is impossible to find, complete, or just a base. I am hoping to find a set of spacers to complete my build.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: B to RB intake adapters [Re: hp383] #2831936
10/12/20 02:16 PM
10/12/20 02:16 PM
AndyF Online content
AndyF  Online Content
I don't think it is that easy, if it was people would use adapters more often. I think you end up with a bit of a dogleg when you try that trick.
Re: B to RB intake adapters [Re: AndyF] #2831951
10/12/20 02:48 PM
10/12/20 02:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I believe they used to make adapters, how they fit I don't know.
https://angeluccimfg.com/products/m...gine-manifold-spacer?variant=27062532673
Re: B to RB intake adapters [Re: Sniper] #2831960
10/12/20 03:01 PM
10/12/20 03:01 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I know they used to be available.
And as far as fitment, my understanding was it just used a valley pan, and a set of paper felpro gaskets and 1 inch longer bolts.
I would just like to find someone that has a set they aren't using, or a place to try and fine a set new or used.
Re: B to RB intake adapters [Re: hp383] #2831980
10/12/20 03:41 PM
10/12/20 03:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I gave you a link to someone selling new ones. Never mind, seems they are out of stock. Might drop them a line and see if they are planning another run?
Re: B to RB intake adapters [Re: Sniper] #2831986
10/12/20 03:48 PM
10/12/20 03:48 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I had already emailed them prior to making my post. I also used the search option and hunted Moparts for older information on the topic.
But other than finding someone someone else asking about them years ago, and reading replies on that post from others saying to just buy a 440 intake because they are cheap at $50-$100 (boy do i miss those days) I hadn't found much info on them. I do remember when they were somewhat common.
Hopefully I can find a set, or that M1 lower section.
Re: B to RB intake adapters [Re: hp383] #2832029
10/12/20 06:20 PM
10/12/20 06:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I made mine out of yellow pine back in the 70s. 383 Torker on a 426 Max, painted with epoxy to seal up. I still have them hanging on the wall. Blew all the minds. Good heat sink. It’s a straight shot with the right thickness and If I did again I’d use the multi ply Baltic birch, stronger, same thing I make carb spacers out of.
Re: B to RB intake adapters [Re: cudaman1969] #2832109
10/12/20 09:38 PM
10/12/20 09:38 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Mopar Performance used to make them but they don't make anything any more so probably will have to find used ones.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: B to RB intake adapters [Re: moparmarks] #2832213
10/13/20 08:51 AM
10/13/20 08:51 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I found a guy on ebay that sold them. I'll go back thru my emails and see if I can find his name and number. Might be the same person mentioned above. They were really nice.
Re: B to RB intake adapters [Re: Dodgeguy101] #2832216
10/13/20 08:58 AM
10/13/20 08:58 AM
moparmarks Offline
moparmarks  Offline
When using the MP aluminum Stage VI heads on a 413-440 you need the spacers. On a 383-400 you use an RB manifold.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: B to RB intake adapters [Re: Dodgeguy101] #2832218
10/13/20 09:11 AM
10/13/20 09:11 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Originally Posted by DodgMOPAR STAGE VI INTAKE MANIFOLD SPACERS - Standard and Max Wedge
Item Id: 111649054013
End time: Sep-14-15 07:39:55 PDT
Seller:
apprpm (1576)
100.0% Positive Feedback
Member since Jan-19-02 in United States
Location: MI, United StatesI found a guy on ebay that sold them. I'll go back thru my emails and see if I can find his name and number. Might be the same person mentioned above. They were really nice. [/quote
Here is the fellow above that I got a set from. But as you can see its been a few years.
Google Stage VI intake spacers, I think this same guy has an ad for them, he is out of Michigan. Hope it helps.
Re: B to RB intake adapters [Re: Dodgeguy101] #2832219
10/13/20 09:16 AM
10/13/20 09:16 AM
moparmarks Offline
moparmarks  Offline
Dang you have emails from 2015?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: B to RB intake adapters [Re: moparmarks] #2832400
10/13/20 05:47 PM
10/13/20 05:47 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Yeah, in my personal account. I dont use it much, more like a large memo pad. LOL
Re: B to RB intake adapters [Re: moparmarks] #2832405
10/13/20 05:59 PM
10/13/20 05:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I still have emails from 2004 or so LOL maybe even older!
Re: B to RB intake adapters [Re: NachoRT74] #2832424
10/13/20 06:57 PM
10/13/20 06:57 PM
moparmarks Offline
moparmarks  Offline
I have some maybe from a few months ago.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: B to RB intake adapters [Re: hp383] #2832706
10/14/20 01:24 PM
10/14/20 01:24 PM
IMGTX Offline
IMGTX  Offline
They are easy enough to get made if you know the thickness you need.
Stuff like that I draw up in CAD and send it to a local shop to have it waterjet or lazer cut. I would offer to, but I literally just went through all my gaskets yesterday and have no bb intake gaskets to measure as well as I am not sure the thickness.
Some body on here should have the thickness.
Just a thought
Re: B to RB intake adapters [Re: IMGTX] #2832845
10/14/20 08:50 PM
10/14/20 08:50 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Just a thought
Thickness of the plate I believe should be .850.
Re: B to RB intake adapters [Re: Dodgeguy101] #2833036
10/15/20 01:37 PM
10/15/20 01:37 PM
moparx Offline
moparx  Offline
Just a thought
that thickness sticks in my mind as well. however, if i remember it right, 3/4" spacers were used as a starter, then selective gaskets were used on each side of the plates to best center the ports of the manifold to the head ports. when all was said and done, the total thickness [plate plus gaskets] was approximately .850.
i looked in an old MP engine book that talked about adapter plates, but those plates were for B-1 heads only.
as you said, someone here should have the dimensions of those spacers.
beer
Re: B to RB intake adapters [Re: moparx] #2834566
10/19/20 11:30 AM
10/19/20 11:30 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I was able to find a set.
And a member here also had a set, but I had purchased the others beforehand.
Re: B to RB intake adapters [Re: hp383] #2834580
10/19/20 11:51 AM
10/19/20 11:51 AM
moparx Offline
moparx  Offline
how thick were they ?
beer
