Page 3 of 4 1 2 3 4
Re: 10 gallon plastic fuel cell and brackets [Re: moparts] #2830263
10/08/20 10:13 AM
10/08/20 10:13 AM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
SOLD!!!!
I have for sale a used 10 gallon plastic fuel cell that I believe came from Summit Racing a number of years ago. It’s in excellent shape and comes with the attaching brackets. This cell does not have a fuel level sending unit as it was in a drag car. It has foam on the inside, had two -8 AN male fittings for the outlet and one -6 AN male fitting for the vent. This cell has no leaks, damage or cracks of any kind. It measure 15” front to back, 20” left to right and 8” high. The sump is 2” deep. The link is for an 8 gallon cell and the only difference is that this cell is higher.
https://www.summitracing.com/parts/sum-290103
https://www.summitracing.com/parts/sum-290152
I would like to get $85.00 plus the shipping for everything.
Edison, NJ
rider1454 at aol.com
Re: Complete SB dual valve spring setup, NEW [Re: PHYSIXX] #2830264
10/08/20 10:16 AM
10/08/20 10:16 AM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a complete SB dual valve spring setup that includes all of the valve springs, 10 degree retainers, Teflon type seals and 10 degree keepers. All from Comp Cams and was to be used on a 340 engine.
https://www.summitracing.com/parts/cca-995-16
https://www.summitracing.com/parts/cca-740-16
https://www.summitracing.com/parts/cca-505-16
https://www.summitracing.com/parts/cca-626-16
The valve springs have both an inner and outer spring with a 1.437 OD, 115 lbs of seat pressure at 1.700” and lbs 336 open pressure at 1.150” with a spring rate of 402 lbs/in and coil bind at 1.02”. The retainers have a .690” ID and use 10 degree keepers. The keepers are the 4 groove design and are 10 degree design to go with the retainers. The seals are the positive stop design made of PTFE material, for a 3/8 valve stem and a .530” valve guide top. All of these parts have never been used and are still in the original packaging. I would like to get $200 for everything shipped to any of the 50 states.
Edison, NJ
Re: Assortment of -10 AN (5/8") fittings [Re: PHYSIXX] #2830266
10/08/20 10:19 AM
10/08/20 10:19 AM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a bunch of -10 AN (5/8”) fittings that are in good useable shape other than a few may need some cleaning from sitting for a long time. Some are Earl’s, some are Aeroquip and some are Russel. There are 12 straight hose ends, 1 straight hose end to ½” NPT, 1 straight bulkhead connector with the nut, 3 AN to ½” NPT fittings, 1 -10 to -08 reducer, 1 90 degree hose end, 1 180 degree hose end and 1 swivel connector. A total of 21 fittings in all. New Aeroquip fittings would cost over $290. I would like to get $125 for everything shipped to any of the 50 states.
Edison, NJ
Turbo Action pro series 8" 904 converter [Re: PHYSIXX] #2830661
10/09/20 08:21 AM
10/09/20 08:21 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Turbo Action
Pro Series 8" Steel Stator converter for 904
For transbrake use
Part # 19918-44
Serial # 01001
Very little use
$725 firm shipped
Neilgoyer@gmail.com
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2830908
10/09/20 07:08 PM
10/09/20 07:08 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Brand new lightweight 4.38 Racetec forged pistons 1.32 comp height $400 plus ship
Build a 512 with a 4.25 crank and a 6.53 rod.
piston invoice.pdf (20 downloads)
Without Data, you’re just another guy with an opinion.
Comp roller lifters (SOLD) [Re: BryanRad] #2831532
10/11/20 01:58 PM
10/11/20 01:58 PM
Missouri
galen Offline
galen  Offline
Missouri
SOLDComp 96829-16. New, never taken out of the box. Went a different direction. 425$ shipped to lower 48. Send a PM
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2831611
10/11/20 04:47 PM
10/11/20 04:47 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Hughes Racing aluminum rocker arms. 1.6 ratio, non cryo. The 1520L and 1525L are brand new, the 1520R and 1525RH are used (minor impact marks from broken valve but wheels still smooth, pins tight, and inner races are smooth). Had these as spares, but no longer have this car.
$75 shipped to lower 48.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Keith Black Aluminum 540 [Re: moparts] #2831637
10/11/20 05:44 PM
10/11/20 05:44 PM
Northeast Texas
MoparMuscle Offline
MoparMuscle  Offline
Northeast Texas
Sold
2020-09-20 11.12.12.jpg (1371 downloads)
2020-09-20 11.10.37.jpg (1364 downloads)
2020-09-20 11.11.40.jpg (1367 downloads)
2020-09-20 11.14.07.jpg (1364 downloads)
100% Mopar No Juice Added 1993 Daytona 2001 Stratus R/t 2001 Ram 2500 Cummins 1993 Foretravel GrandVilla 3116 Cat Allison 6 spd http://moparmuscle.biz
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2832111
10/12/20 09:39 PM
10/12/20 09:39 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Milodon oil system parts. What you see is what you get. $300 or BO, plus shipping. Parts located near Buffalo NY. IM me here if interested.
IMG_2035 - Copy.JPG (1486 downloads)
IMG_2036 - Copy.JPG (1482 downloads)
IMG_2037 - Copy.JPG (1485 downloads)
68 Road Runner (383/4speed, post car w/decor pkg)
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
Re: For Sale - Race Parts - 4th Quarter [Re: RoadRunner] #2832196
10/13/20 07:52 AM
10/13/20 07:52 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Diamond stroker pistons for 5.7
New in box
3.947 bore (+ .030)
1.090 compression height
11.5 cc dome
2618 alloy
Takes 1.5, 1.5, 3.0 rings
Takes .927 x 2.400 pin
No pins or rings, oil ring support rails included
These work with 4.050 stroke 6.125 rod, 3.900 stroke 6.200 rod, or 3.795 stroke 6.250 rod
$425 shipped
Neilgoyer@gmail.com
NOS W2 MP Tunnel Ram [Re: moparts] #2832669
10/14/20 12:25 PM
10/14/20 12:25 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
FOR SALE:
NOS Mopar Performance W2 Tunnel rams
SOLD
pn 2.jpg (1326 downloads)
tunnel ram ports.jpg (1327 downloads)
Re: NOS W2 MP Tunnel Ram [Re: UCUDANT] #2832732
10/14/20 02:15 PM
10/14/20 02:15 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Ray Barton Hemi intake & exhaust rocker. Intake is 1.60 Ratio, Exhaust is 1.50 Ratio These were kept as spares and are new. $250 Free shipping in the lower 48 (708)987-2394 Don
[Linked Image] [Linked Image]
Re: NOS W2 MP Tunnel Ram [Re: OUTLAWSSAA] #2832740
10/14/20 02:31 PM
10/14/20 02:31 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Turbo Start 16 volt step down resistor Pt#16VRES. This item is new in the box with instruction sheet. Jegs sells for $150. My price $75 + shipping (708)987-2394 Don
Re: NOS W2 MP Tunnel Ram [Re: OUTLAWSSAA] #2834340
10/18/20 08:03 PM
10/18/20 08:03 PM
K
KOS Offline
KOS  Offline
K
Milodon bronze dist/oil pump drive gear NEW $100
Hussey 4.5+bore .093 copper head gaskets NEW $150
Comp cams hyd roller pushrods for RB wedge .080wall 9.0 long.$150
PM me
Thumper 1250 Carb [Re: KOS] #2834350
10/18/20 08:34 PM
10/18/20 08:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Reason for selling is I am going billet...
Carb was $1300 new plus conversion....I have over $1800 into this carb, sell for $1100
This is a converted Holley G3 Ultra from 3-circuit to 2-circuit.
Used on a 605 Hemi
Tuned with an AFR gauge
Ran on 93 pump gas w/10% Ethanol
Takes a different fuel log than standard Dominator
https://www.holley.com/products/fue..._gen_iii_ultra_dominator/parts/0-80908BK
'71 Duster 400/512
https://www.youtube.com/watch?v=Znuo3jMUXTk (6.00 at 114.05mph)
https://www.youtube.com/watch?v=Y9hxSMAWoII (9.66 at 139mph)
'70 Cuda, Plan C....605 Hemi
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph)(823hp and still tuning)
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2834492
10/19/20 09:06 AM
10/19/20 09:06 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Original 1965 426 HEMI A990 Super Stock Magnesium crossram intake manifold with 3116 Holley carbs, the intake is original and the carbs are original, the linkage kit and carb adapter plates are new reproduction, the carbs have not been ran in a long time and I would call them cores to restore $4000.00 (708)288-2879
hemi crossram 002.JPG (822 downloads)
hemi crossram 004.JPG (818 downloads)
hemi crossram 010.JPG (823 downloads)
hemi crossram 013.JPG (820 downloads)
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2834498
10/19/20 09:16 AM
10/19/20 09:16 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1965 A990 426 HEMI Super Stock exhaust, excellent used condition $4500.00 for the five pieces (708)288-2879 Scott
hemi exhaust 002.JPG (814 downloads)
hemi exhaust 009.JPG (817 downloads)
hemi exhaust 013.JPG (812 downloads)
hemi exhaust 025.JPG (818 downloads)
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2834500
10/19/20 09:21 AM
10/19/20 09:21 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Mopar Performance 426 HEMI SIX PACK intake manifold, part number P5153738, brand new in the box, never been installed on an engine, Jegs price $706.99 my price $475.00 (708)288-2879 Scott
parts 3-13-2020 025.JPG (808 downloads)
parts 3-13-2020 019.JPG (806 downloads)
parts 3-13-2020 023.JPG (814 downloads)
parts 3-13-2020 026.JPG (810 downloads)
Re: For Sale - Race Parts - 4th Quarter [Re: dsd70bee] #2834766
10/19/20 08:05 PM
10/19/20 08:05 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Indy Crossram Intake Stuffers
These are the resin stuffers were made to set in the wedge bathtub intake.
$100+ the ride
Re: For Sale - Race Parts - 4th Quarter [Re: Whompin_Wedge] #2835496
10/21/20 10:16 AM
10/21/20 10:16 AM
Oil City PA
1baddart Offline
1baddart  Offline
Oil City PA
540 turbo motor. Iron mega block, 4.440 bore, 4.375 stroke, billet cw crank, diamond 10.5:1 pistons, GRP promod rods, custom turbo cam, crower bushed lifters, pushrod oiling, mylodon billet oil pump, Charlies oil pan, copper head gaskets, o ringed heads, b1 originals heavily ported, t&d rockers, custom billet runner sheet metal intake, air to water intercooler, 123mm Wilson throttle body, ATI balancer. less than 20 passes on the motor. makes almost 2000hp to the wheels on low boost. $20000 obo. j_noel669@hotmail.com 814-673-4870 or pm. still in car- can hear run and go for a ride. Can negotiate the stainless turbos and piping.
Page 3 of 4 1 2 3 4
