Re: Ford 4.0 Engine questions - Torque to yield fasteners
[Re: MoparKansas]
#2831866
10/12/20 11:59 AM
10/12/20 11:59 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
They stretch - can't reuse them.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#2831887
10/12/20 12:40 PM
10/12/20 12:40 PM
Posts: 6,217 nowhere
Sniper
nowhere
Amazon has them for a lot less, put the Ford part numbers in the search there. You realize that Ford, in their infinite wisdom, but one timing set on the back of the engine necessitating the removal of the engine or the trans to do the job, they claim you can separate the two to get enough room, didn;t work for me.. BTDT with my daughter's Exploder. You really need the proper tools to time the engine as they aren't keyed and misalignment is probable without the timing tools. You can get those on Amazon too. https://www.cloyes.com/1997-2011-fo...-timing-replacement-cloyes-kit-9-0398sb/
[Re: Dcuda69]
#2832189
10/13/20 06:36 AM
10/13/20 06:36 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Some torque to yield bolts can be reused according to the manufacturer. If Ford says to replace them, then replace them, if not then reuse them if they aren't deformed.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
