Ford 4.0 Engine questions - Torque to yield fasteners #2831862
10/12/20 11:52 AM
10/12/20 11:52 AM
KS
MoparKansas Offline OP
KS
My daughter's 2006 Mustang has been a decent first car for her, but recently the timing chain guides went out as it sounds like these engines are known for. I think the jackshaft and cam sprocket fasteners are torque to yield and the Ford dealer wanted $79 for one stinking bolt. Can these be reused or does anyone have a source that would be cheaper than the dealer? I can't seem to find them new online anywhere.
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: MoparKansas] #2831866
10/12/20 11:59 AM
10/12/20 11:59 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
They stretch - can't reuse them.
Ride eternal, shiny and chrome
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: DirectSubjection] #2831887
10/12/20 12:40 PM
10/12/20 12:40 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Amazon has them for a lot less, put the Ford part numbers in the search there.
You realize that Ford, in their infinite wisdom, but one timing set on the back of the engine necessitating the removal of the engine or the trans to do the job, they claim you can separate the two to get enough room, didn;t work for me.. BTDT with my daughter's Exploder. You really need the proper tools to time the engine as they aren't keyed and misalignment is probable without the timing tools. You can get those on Amazon too.
https://www.cloyes.com/1997-2011-fo...-timing-replacement-cloyes-kit-9-0398sb/
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: Sniper] #2831900
10/12/20 12:56 PM
10/12/20 12:56 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
You might want to check Pep Boys or Auto Zone to see if the special alignment tools are part fo their tool-loan program.
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: MoparKansas] #2832069
10/12/20 08:13 PM
10/12/20 08:13 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Torque to yield bolts are not supposed to be re-used. But we have done it countless times. Especially on head gaskets. Someone who has experience torquing bolts can usually feel if the bolt holds torque as it is put through it's last twist.
twocents
Master, again and still
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: DaveRS23] #2832090
10/12/20 08:51 PM
10/12/20 08:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Reusing TTY bolts invites two issues. Insufficient clamping force and fastener failure....or both
Re: Ford 4.0 Engine questions - Torque to yield fasteners [Re: Dcuda69] #2832189
10/13/20 06:36 AM
10/13/20 06:36 AM
Guitar Jones Offline
Some torque to yield bolts can be reused according to the manufacturer. If Ford says to replace them, then replace them, if not then reuse them if they aren't deformed.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
