Drop spindles? #2831606
10/11/20 04:29 PM
10/11/20 04:29 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I'm looking for your opinions on whose drop spindles to get for a Dart. Thanks
Re: Drop spindles? [Re: 80arrow] #2832154
10/12/20 11:15 PM
10/12/20 11:15 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
magnum farce is about the only ones youll find.. sorry
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Drop spindles? [Re: HOTMOPR] #2832457
10/13/20 08:40 PM
10/13/20 08:40 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
Magnum force, Firm Feel, Fatman Fab are a few that sell them. I have no experience with any of them but i would like to get a set from somebody one day.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Drop spindles? [Re: 80arrow] #2832852
10/14/20 09:23 PM
10/14/20 09:23 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Are you doing this for function or appearance?
Re: Drop spindles? [Re: Wirenut] #2832883
10/14/20 11:31 PM
10/14/20 11:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
x2
Re: Drop spindles? [Re: 80arrow] #2832903
10/15/20 02:23 AM
10/15/20 02:23 AM
What year Dart, early, pre 1967 or 1967 and later bigger A body?
I think the 1967 to 1972 spindles are the same and changed on the V8 cars in 1973 scope
I'm not sure about the 1961 to 1966 A bodies spindles confused
Re: Drop spindles? [Re: Wirenut] #2833177
10/15/20 09:39 PM
10/15/20 09:39 PM
8
80arrow Offline OP
80arrow  Offline OP
A little of both. I'm trying to get the whole car a little lower for stability and looks. I have an aftermarket coil over front end in it now but where it sits, the coilsprings are set as loose as possible and I'd like it lower. It's a '71 Dart with big ball joints.
Re: Drop spindles? [Re: nasty68] #2833179
10/15/20 09:44 PM
10/15/20 09:44 PM
8
80arrow Offline OP
80arrow  Offline OP
That's what I've seen also. I've read that the Fatman ones don't look to strong. And that the Magnum Force in general I should stay away from, customer service reasons, I guess. I think the Firm Feel are the same as the ones Magnum Force sells, I was going to call them. A member here has a set of PST drop spindles, for sale I guess, but I can't find them on their website and he hasn't replied to me for a few days??
Re: Drop spindles? [Re: 80arrow] #2833208
10/15/20 10:50 PM
10/15/20 10:50 PM
AndyF Offline
AndyF  Offline
I haven't seen a Mopar dropped knuckle yet that I'd put on my own car. They all look like 6th grade shop projects to me.
Re: Drop spindles? [Re: AndyF] #2833296
10/16/20 08:35 AM
10/16/20 08:35 AM
8
80arrow Offline OP
80arrow  Offline OP
I haven't seen any of them so that's why I'm asking, lol.
Re: Drop spindles? [Re: 80arrow] #2833307
10/16/20 09:01 AM
10/16/20 09:01 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Magnum Force drop spindles in use for over 12k miles
NMCA NSS 67 Coronet
Re: Drop spindles? [Re: 80arrow] #2833370
10/16/20 11:00 AM
10/16/20 11:00 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Most/many coil over Mopar aftermarket set-ups use a modified mustang2 spindle, completely different then any OEM mopar spindles. If this is the case, you are looking for a very selective/rare spindle offering.
Re: Drop spindles? [Re: 80arrow] #2833432
10/16/20 12:09 PM
10/16/20 12:09 PM
AndyF Offline
AndyF  Offline
If you have an aftermarket coil over front suspension then you most likely don't have Mopar knuckles in the car. You'll be in for a big surprise if you buy a Mopar knuckle since it won't fit. Better take a picture of what you have before you buy anything.
Re: Drop spindles? [Re: AndyF] #2833566
10/16/20 04:52 PM
10/16/20 04:52 PM
8
80arrow Offline OP
80arrow  Offline OP
It's a Bondo Bob front end. I installed it a couple years ago and put my Mopar spindles on it. It was designed to use them.
Re: Drop spindles? [Re: jcc] #2833568
10/16/20 04:54 PM
10/16/20 04:54 PM
8
80arrow Offline OP
80arrow  Offline OP
It has Mopar spindles
Re: Drop spindles? [Re: 80arrow] #2833768
10/17/20 09:00 AM
10/17/20 09:00 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The Magnum Force spindles are basically a dropped late model a-body disc spindle. It fits A or B bodies with the large upper ball joint. Took a few months to get from them. I have a set if you need them right away.
Re: Drop spindles? [Re: fbs63] #2833788
10/17/20 10:11 AM
10/17/20 10:11 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
They fit E-bodies as well.
Re: Drop spindles? [Re: burdar] #2834696
10/19/20 04:34 PM
10/19/20 04:34 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I have 3 sets of the Magnum Force spindles, nicest spindle I ever got. The spindle from when I was talking with Ron at the shop is that these are twice the strength of the factory forging if I remember correctly. One set is for my Transformer 70' CUDA that will just be a fun street brawler. Two other sets are for corner carving rods for a future build. I know of at least 2 dozen cars that run these and never heard a complaint or problem and my last car I sold had these on it and handled good since we didn't have to turn down the torsion bar to make it look good.
Re: Drop spindles? [Re: migsBIG] #2834724
10/19/20 06:10 PM
10/19/20 06:10 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My research suggests the Magnum force drop spindles are Ductile Iron, a fairly tough material, there are a number of Ductile Iron grades with different mechanical properties. It is heat treatable. I'm doubtful Mag Force is using the higher rated/heat treated grades. I was also under the impression my older OEM spindles were forged steel, which if so, they are of comparable strength with ductile iron, and the steel forgings slightly better in the fatigue area. If the Mag Force claim was for a typical cast iron/steel spindle, then their higher strength claim would be valid IMO. I don't see any big strength shortcomings with the Ductile Iron Mag Force dropped spindles, the only reasonable alternative would be billet CM or forgings, which in a 2" dropped version would be a very small market, and likely rather pricey.
I have a set of Mag Force dropped spindles, I polished, plated, baked, and had cyro'd.
https://www.sae.org/publications/technical-papers/content/2007-01-1001/
Re: Drop spindles? [Re: jcc] #2834837
10/20/20 12:45 AM
10/20/20 12:45 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
The magnum force are nice. Just don't expect them to be ready to ship when they say.. Took a couple months to get mine. I also run the SCT upper a arms to get it to align. QA1 everywhere else..
