Page 3 of 3 1 2 3
Re: Spoke too soon about MAgnafuel Pumps [Re: moparx] #2832330
10/13/20 02:45 PM
10/13/20 02:45 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by moparx
i have an aeromotive 340 pump i plan to install in the tank of my charger.
i plan on using the 3/8" line that's there [not much hp] and running a 1/2" return.
electrically, i plan on using heavy gauge wire and a relay, but i don't understand why the magnafuel pump requires a double relay. shruggy
can anyone explain ? TIA.
beer
Its redundant.....not necessary
Typical Moparts...SMH people love to bash on here
....BAD A$$ STREET CAR.....
Re: Spoke too soon about MAgnafuel Pumps [Re: justinp61] #2832393
10/13/20 05:34 PM
10/13/20 05:34 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
For the third time, the pump was not dead headed....
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2833138
10/15/20 08:01 PM
10/15/20 08:01 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I must live right, I have a 500 mounted vertically in pipe car that is 8 to 10 years old. Took it apart 2 months ago because of a pinched inlet hose, looked fine sounds fine. Also have a 500 mounted horizontal in my door car that is 6 years old, put a seal in once. I do make sure my regulated bypass is at 26-28# and every fall I drain all the fuel (gasoline), then spray gobs of WD-40 into it. I do always carry a spare, that’s probly why mine never quits. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
1980 Plymouth Arrow 572 Hemi.
242" Mullis Dragster. 6.90@ 200mph
Page 3 of 3 1 2 3
