Pistons, what brand, what options? #2830144
10/07/20 08:53 PM
10/07/20 08:53 PM
gregsdart Offline OP
I have my name on a World aluminum block, and may buy new pistons to best match the combo. I talked to Ross pistons today and got some ideas. For sure what i want is .043 , .043, 3mm low tension rings, gas ports and skirt coatings. Ed at Ross suggested .200 wall pins from tool steel. This will be the same configuration, 550 cubes, 15/1 compression.
What piston brands are good, and any options i should consider?
Re: Pistons, what brand, what options? [Re: gregsdart] #2830154
10/07/20 09:48 PM
10/07/20 09:48 PM
Washington
madscientist Offline
Washington
I like the last 10 or so sets of Ross pistons I’ve seen. They are at least as good as anything else, and better than a bunch of stuff.
Before I picked a ring pack, I’d call Total Seal and ask THEM what they think you should run for rings. IMO, and .043/.043 ring pack is a bit thick, even on a bracket engine. I’d let them pick the ring pack and rings.
Re: Pistons, what brand, what options? [Re: madscientist] #2830220
10/08/20 07:59 AM
10/08/20 07:59 AM
The Great White North
RAMM Offline
RAMM  Offline
I would call Diamond and have a convo with Ron--He's a Mopar guy and has good advice and experience. Or I see Mahle Motorsports now has a Custom department which I am looking forward to using. J.Rob
Ron Beaubien - Senior Sales Representative
rbeaubien@diamondracing.net
Phone: 586-792-6620 x 6125
Strengths: 20+ years with Diamond Pistons, specializes in Mopar, factory replacement, drag racing and circle track applications.
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Pistons, what brand, what options? [Re: gregsdart] #2830225
10/08/20 08:23 AM
10/08/20 08:23 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You might consider Gibtec in Denver. They are part of V Gaines' Western Motorsports group in Denver. The group includes Winberg Cranks, GRP Rods, etc.
You also might want to consider Total Seals "gas ported rings". Dyno tests show they can make more power than gas ports.
Re: Pistons, what brand, what options? [Re: 340Cuda] #2830255
10/08/20 09:55 AM
10/08/20 09:55 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
https://www.speed-talk.com/forum/viewtopic.php?t=60301
Call Rebco in Wichita, KS and see what they recommend.
They do pistons for a lot of high end racers.
REBCO MACHINE, INC.
1100 W. 37TH STREET N.
WICHITA, KANSAS 67204
Phone 316-440-2828
Fax 316-440-2849
Email ERICHENKE@REBCOMACHINE.KSCOXMAIL.com
'63 Dodge 330
11.19 @ 121 mph
Re: Pistons, what brand, what options? [Re: gregsdart] #2830269
10/08/20 10:22 AM
10/08/20 10:22 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Greg, I would call Icon pistons. They have the best slipper design in the business. Plus you can get the line to line slipper coating. Call 775-882-78790 and ext. 159 ask for Glen. They have been making pistons since 1922
Re: Pistons, what brand, what options? [Re: merpar] #2830363
10/08/20 01:12 PM
10/08/20 01:12 PM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
Not even close
Re: Pistons, what brand, what options? [Re: gregsdart] #2830367
10/08/20 01:19 PM
10/08/20 01:19 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I'd talk with Todd. You are already getting the block from him. He won't steer you wrong. He is doing my KB wedge and going with Diamond pistons on my build. I have heard that many of the piston suppliers are way behind due to the shut down.
Ok
Re: Pistons, what brand, what options? [Re: gregsdart] #2830370
10/08/20 01:30 PM
10/08/20 01:30 PM
AndyF Offline
AndyF  Offline
Work with your engine builder. Typically it comes down to who he has a good relationship with. There are a lot of little details that need to be talked over so people tend to work with the same people over time. Any of the good piston vendors can build what you want, it is the relationship that seals the deal.
Re: Pistons, what brand, what options? [Re: cudatom] #2830400
10/08/20 02:21 PM
10/08/20 02:21 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pistons, what brand, what options? [Re: LSP] #2830492
10/08/20 06:00 PM
10/08/20 06:00 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Not even close??
Re: Pistons, what brand, what options? [Re: merpar] #2830502
10/08/20 06:23 PM
10/08/20 06:23 PM
PA
moparacer Offline
moparacer  Offline
PA
I have used Ross, Diamond, JE, and the Weisco's in my engine now have been to hell and back.
Never had any problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Pistons, what brand, what options? [Re: gregsdart] #2830913
10/09/20 07:18 PM
10/09/20 07:18 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Greg, I used Diamond pistons and they have a dome shaped to match the Indy 440-1 heads which might help in a high compression build... Work good for me!
Good Luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Pistons, what brand, what options? [Re: cudabin] #2830959
10/09/20 09:57 PM
10/09/20 09:57 PM
PA
Scully Offline
Scully  Offline
PA
A household name at one of the big engine parts companies told me that Ross makes a lot of pistons for some of the other piston companies, he made me promise not to say he said it.
Re: Pistons, what brand, what options? [Re: Scully] #2831070
10/10/20 10:41 AM
10/10/20 10:41 AM
Washington
Washington
LOL...glad you can keep a secret!!!!!
Re: Pistons, what brand, what options? [Re: merpar] #2831072
10/10/20 10:45 AM
10/10/20 10:45 AM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
Not even close??
Let's see a picture of the "best in the business" slipper style piston, then I'll show you mine.
Re: Pistons, what brand, what options? [Re: LSP] #2831085
10/10/20 11:21 AM
10/10/20 11:21 AM
Not even close??
OMG, another mine is better than yours whistling
I've used a bunch of different piston makers in my long engine building and racing career, some where not as good as others but I know now to you buy a custom race piston for a race motor and not to buy a expensive race piston for a street and strip motor tsk twocents
I placed a order for a set of Probe shelf pistons for a pump gas RB motor with the Summit several years back, Summit racing side told me they would be drop shipped directly to me in 3 to 6 weeks. 10 months later I called Probe and ended up talking to another holding company who had bought them out along with several other SO CA piston companies, I got them several weeks later and they where made by Auto Tec shock
I've had really good luck with Icon on pump gas street motors up Quality product at a reasonable price boogie
Re: Pistons, what brand, what options? [Re: Cab_Burge] #2831102
10/10/20 12:02 PM
10/10/20 12:02 PM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
He said "best in the business", I'd like to see it is all
Re: Pistons, what brand, what options? [Re: LSP] #2831352
10/10/20 09:50 PM
10/10/20 09:50 PM
I did not key on that or realized that had been said blush
Re: Pistons, what brand, what options? [Re: Cab_Burge] #2831654
10/11/20 06:19 PM
10/11/20 06:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I prefer CP personally, but have a relationship there too. I have used Diamond and Ross in the past. Use Rebco for some stuff, usually changes or further profiling made after manufacture. Yes even with molds or digitized chambers sometimes stuff changes slightly and needs addressed. But we are talking ultra high compression stuff. Been to the Gibtec facility and it is very nice and they do a fair number of billets for Pro Stock and Pro Stock bike.
