Page 2 of 4 1 2 3 4
Re: The best Rear main Seal for a 440? [Re: BloFish] #2827097
09/30/20 09:10 PM
09/30/20 09:10 PM
Kirkland, Washington
Pacnorthcuda Offline
I’ve done two on 440’s, one in the 90’s, a Mopar Performance seal, and another in the 00’s, a Superformance orange seal. Neither leaked.
Re: The best Rear main Seal for a 440? [Re: ZIPPY] #2827114
09/30/20 09:23 PM
09/30/20 09:23 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
So on a modern build, myself I substitute RTV for the side seals. I try to inject it inside the groove
as much as possible and also pack that area using putty knife/fingers and so on.
I've been doing it that way since about 1975.
Re: The best Rear main Seal for a 440? [Re: DrCharles] #2827360
10/01/20 12:36 PM
10/01/20 12:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by DrCharles
Quote
I did that on my current 451 and it worked perfectly. I just made sure to get the seal holder and the block operating-room clean before applying it. up
RTV cures from exposure to moisture, inserting a wet pipe-cleaner into the wet RTV not only promotes fast cure but also expands the RTV into every corner of the groove.
Re: The best Rear main Seal for a 440? [Re: John_Kunkel] #2827773
10/02/20 10:05 AM
10/02/20 10:05 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Great feedback so far guys. Keep the tips coming, they are very useful. Thanks!!!
Re: The best Rear main Seal for a 440? [Re: Fasbird] #2827915
10/02/20 02:31 PM
10/02/20 02:31 PM
moparx Offline
moparx  Offline
there was a thread recently that showed a billet retainer modified to resemble the engine side of the factory retainer.
this acted as a deflector, throwing the oil back toward the pan.
i'm too stupid to know when that was, or if i did remember, i couldn't link to it.
maybe someone remembers this ? shruggy
help out an old doofus with "oldtimers" and CRS please.
beer
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2827945
10/02/20 03:23 PM
10/02/20 03:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Cab_Burge
I have used a thin layer of adhesive silicone on the back side to hold the seals to block and seal holder and i ALWAYS use wheel bearing grease on the lip edges of the seal and on the main seal area of the crank surface up
I have never tried installing the seals and crank dry, NEVER twocents
Not talking about the seal just the retainer, once oil is on the side pieces they expand tight, rtv in the corners and bottom, Vaseline on the crank where the seal rides
Re: The best Rear main Seal for a 440? [Re: moparx] #2828365
10/03/20 05:37 PM
10/03/20 05:37 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
beer
Here's mine:
Re: The best Rear main Seal for a 440? [Re: DGS] #2828916
10/05/20 12:47 PM
10/05/20 12:47 PM
moparx Offline
moparx  Offline
that's the picture ! up
thank you sir !
beer
Re: The best Rear main Seal for a 440? [Re: moparx] #2828934
10/05/20 01:14 PM
10/05/20 01:14 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Interesting, I have an old pan from a 71 New Yorker with a 375 horse 440
that has a baffle at the back of the pan, "U" shaped to help keep oil off the seal.
I wonder why that wasn't used on other hipo cars, or was it??
Joe
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2829437
10/06/20 05:55 PM
10/06/20 05:55 PM
moparx Offline
moparx  Offline
that's interesting.
i have never seen anything like that.
do you, by chance, have any pics of that pan ?
beer
Re: The best Rear main Seal for a 440? [Re: moparx] #2829563
10/06/20 10:08 PM
10/06/20 10:08 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Moparx, send me an email, jlatessa@roadrunner.com
and I'll attach the pic to you.
Format not allowed by MOPARTS
Joe
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2829759
10/07/20 11:54 AM
10/07/20 11:54 AM
Cab_Burge Online work
Cab_Burge  Online Work
Joe
I have owned and used several of those type pans also up I think Mopar started using them in 1971 on the C body cars and maybe in the BB Cordoba also later shruggy
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2829784
10/07/20 12:28 PM
10/07/20 12:28 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think when I remove the pan on one of our cars, I may cut out that baffle and attach it to the 6 Qt. pan.
the sump baffle is the best I've seen on a stock pan too.
Joe
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2829899
10/07/20 03:37 PM
10/07/20 03:37 PM
Why not build a duplicate of that rear baffle and use it instead of ruining the stock pan work twocents
How about you making a crankshaft scraper for the passenger side of the block now to use also up wrench scope
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2829991
10/07/20 04:31 PM
10/07/20 04:31 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
OK, I knew someone would suggest that, I agree.
As far as a scraper for our cars, I'm not sure we would benefit much as they both shift below 6000.
I'll take some measurements and I know someone who waterjets, so maybe I can make a few.
Joe
As an aside, it looks like the baffles are brazed in, right?
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2830329
10/08/20 11:54 AM
10/08/20 11:54 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Here's a pic of the 187 pan...Joe
Looks like the main baffle is spotwelded, but the
rear baffle brazed, maybe not enough flange or room
Re: The best Rear main Seal for a 440? [Re: Fasbird] #2830358
10/08/20 12:59 PM
10/08/20 12:59 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Fast Fish auto parts
You're welcome
Re: The best Rear main Seal for a 440? [Re: GomangoCuda] #2830388
10/08/20 02:03 PM
10/08/20 02:03 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Originally Posted by GomangoCuda
Quote
How has it worked out for you in all that time?
Rich H.
Esse Quam Videri
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2830464
10/08/20 04:30 PM
10/08/20 04:30 PM
moparx Offline
moparx  Offline
THANKS for the pic Joe ! up bow
in all my years, i have never seen a 187 pan like that !
beer
Re: The best Rear main Seal for a 440? [Re: moparx] #2830623
10/09/20 01:53 AM
10/09/20 01:53 AM
beer
That is not a stock 187 pan tsk
Someone with good skill added all of those hand made pieces bow up
I have used many of those stock pans that I added front and rear baffles along with the stock Mopar windage trays and home made crankshaft scrapers to to use in 1967 to 1976 A body cars with BB Mopar motors in them for street and strip use with good results up
Mine didn't look as good as that one though blush
Page 2 of 4 1 2 3 4
