Moving the PowerBand Lower
#2829631
10/07/20 07:06 AM
10/07/20 07:06 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
505" 440. 11.9 cr. 271@.050 roller 106 c/l @106. .609 lift Std port heads. Estimated powerband now 4 ,000 to 6,500-ish Would like to launch lower with out laboring the engine. Has plenty of SLR 15.56 now. Would like to leave at 2,500 or 3 000 and let the torq do all the work instead of the clutch. Currently takes more base to launch than hold 4th. Don't need to go this fast anyway. Often 60ft.s with the back tires. Smaller cam and less compression is not out of the question. Advancing this cam would yield some improvement, but wouldn't think it would be enough.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Moving the PowerBand Lower
[Re: 80fbody]
#2829638
10/07/20 08:22 AM
10/07/20 08:22 AM
6bblFLASH
N.E. Ohio
Would require added base pressure. Which I would have to add anyway... but am concerned about lugging the engine and detonation. I think I will have to lower the compression to launch that low safely. Tried launching at 4,000 a few times. Carried the front 80+ft. Maybe pull some timing would be better.
[Re: 6bblFLASH]
#2829735
10/07/20 11:27 AM
10/07/20 11:27 AM
Posts: 43,118 Bend,OR USA
Cab_Burge
If the ignition timing change doesn't work I would, and do, advance the cam from 3 to 6 degrees on the intake lobe center Look closely at the reaction and 60 ft. times when testing both
[Re: 6bblFLASH]
#2829832
10/07/20 02:07 PM
10/07/20 02:07 PM
Posts: 268 Anchorage, Alaska
metallicareload
Anchorage, Alaska
You all are out of my league, please excuse my dumb comments but: what about moving the car to the power band with gearing? Though it looks like you'd be bouncing off the rev limiter on the top end, if you arent already? What launch RPM is safe?
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#2830054
10/07/20 05:47 PM
10/07/20 05:47 PM
6bblFLASH
N.E. Ohio
You all are out of my league, please excuse my dumb comments but: what about moving the car to the power band with gearing? Though it looks like you'd be bouncing off the rev limiter on the top end, if you arent already? What launch RPM is safe? I normally launch at 5,000,,,,,,,shift at 6,500 and trap about 6,800. It works pretty good, but is killing the clutch at this current style of run. However it is a bracket killer. At Keystone in 4 rds. 009,, 009,, .030,, .009 reaction times. Ran .11 off my dial in the semis and lost by .004 due to the clutch going away. 🤬🤬🤬
[Re: 6bblFLASH]
#2830105
10/07/20 08:05 PM
10/07/20 08:05 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Is going to a 3.09 first gear ratio an option? If so, it would drop a thousand rpm off your launch. Made a significant difference in my 4 speed.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2830248
10/08/20 09:50 AM
10/08/20 09:50 AM
6bblFLASH
N.E. Ohio
I have a 3.19 1st ratio now 4.88 rear gear. Not sure I follow "thousand-rpm" with 3.09 ratio???🤔
[Re: 6bblFLASH]
#2830257
10/08/20 10:06 AM
10/08/20 10:06 AM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Would require added base pressure. Which I would have to add anyway... but am concerned about lugging the engine and detonation. I think I will have to lower the compression to launch that low safely. Tried launching at 4,000 a few times. Carried the front 80+ft. Maybe pull some timing would be better. Pulling timing on a timer would seem to be the easiest, and modifieable as well. Then you can retune as you like (cam advance etc) narrower rear tire a possibility?
[Re: 6bblFLASH]
#2830265
10/08/20 10:17 AM
10/08/20 10:17 AM
Posts: 5,999 Salem
Grizzly
Salem
I have a 3.19 1st ratio now 4.88 rear gear. Not sure I follow "thousand-rpm" with 3.09 ratio???🤔 Okay, got it, I thought you might have had the 2.47 first gear.
Mo' Farts
[Re: Grizzly]
#2830283
10/08/20 10:44 AM
10/08/20 10:44 AM
6bblFLASH
N.E. Ohio
No worries. I didn't think about posting all the ratios since it started as an engine question.
