kickdown question #2828952
10/05/20 02:23 PM
10/05/20 02:23 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
Question im switching from a x-ram with a 1 piece trans kick down rod to a inline 2 fours can i use the same rod on the the inline duals?
Re: kickdown question [Re: moparsquid] #2829350
10/06/20 03:47 PM
10/06/20 03:47 PM
moparx Offline
moparx  Offline
would you have a picture of both ?
also, what is this in ?
and i will add my opinion : STAY away from a LOKAR setup, please ! whistling
beer
Re: kickdown question [Re: moparx] #2829370
10/06/20 04:37 PM
10/06/20 04:37 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I used this setup on my dual 4bbl setup.
In my case I had a full manual valvebody, but this setup does allow the use of the original throttle and kickdown stud.
And it is adjustable so you can locate the throttle connection to the original location. That should allow you to use an original single carb setup throttle cable and kickdown linkage I would think.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: kickdown question [Re: moparx] #2831837
10/12/20 10:27 AM
10/12/20 10:27 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
sorry not on the engine yet but its twin carters on a stock manifold in a 62 dart
Re: kickdown question [Re: moparsquid] #2831867
10/12/20 12:03 PM
10/12/20 12:03 PM
moparx Offline
moparx  Offline
if i get a chance later today, or tomorrow, i'll dig out my FSM for that.
it should have a pic of the factory linkage along with the adjusting procedure.
if it does, i'll try to post a pic of that page.
beer
