Pulsing brake pedal, part deux
#282846
04/09/09 06:10 PM
04/09/09 06:10 PM
Posts: 571 central PA
mopartial
central PA
I followed the other thread closely. 99 Dakota 4WD. My pedal pulses vigorously and brakes can shake vehicle to a stop. I do not think warped rotor(s): 1)I do not unevenly or over torque rotors. 2)I do not feel any shimmy in steering wheel upon braking. 3)And with a bad rotor, if you turn wheel by hand you can feel it grab-go, grab-go, grab-go...
So I looked to rear. Put rear axle on jackstands, truck in gear, apply brake, NO pulsation at all. I was thinking if its a drum, I will still have it applying rear brakes like this...
Where is my pulsing pedal coming from?
If it aint broke, dont break it.
Re: Pulsing brake pedal, part deux
[Re: RapidRobert]
#282848
04/10/09 12:08 PM
04/10/09 12:08 PM
mopartial
central PA
When its a bad rotor, I always feel it in the steering wheel when braking. But not now, its only at the pedal...
[Re: mopartial]
#282849
04/10/09 12:20 PM
04/10/09 12:20 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it is pulsating pedal it is most likely the rear brakes. Is it disc in the rear? What is the run out? Note grease/oil on shoes will have a affect on brakes as well. The axle seals ok?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#282850
04/10/09 12:40 PM
04/10/09 12:40 PM
mopartial
central PA
Rear drums. I could replace em but I hate changing parts without knowing whats wrong. When I jacked up rear I couldnt feel it which is why Im not so sure...
[Re: mopartial]
#282851
04/10/09 12:46 PM
04/10/09 12:46 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Unless you have a brake lathe there is no easy way to check runnout.
Allen
[Re: AINTNRT]
#282853
04/10/09 02:45 PM
04/10/09 02:45 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
You think it's not a lot of things but don't know what it is? This is the dirtball way to check when you are SURE it's not the rotors but don't know what it is... Find a SAFE place to do the following: Take a pair of vice grips and pinch off the rear brake hose. Test drive it. Remove the vice grips and pinch off the right front brake hose. Test it. Now move them to the LF. At this point, you should have a good idea where it's coming from. BTW, you also have to replace the hoses you just crimped!
[Re: RodStRace]
#282854
04/10/09 03:07 PM
04/10/09 03:07 PM
mopartial
central PA
Thats a great method except for the ruined hoses part...
If I had a brake lathe I wouldnt be asking for advice here. Maybe the mechanic I know will check em for me. I dont usually have em turned anymore cause labor cost = price of new. And if I just start replacing things, then Im a "parts changer".
[Re: mopartial]
#282855
04/10/09 03:19 PM
04/10/09 03:19 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Since it is a 99 you should be able to use a tool made for the factory soft hoses and get away with it. Just don't over tighten.
Allen
[Re: RapidRobert]
#282857
04/10/09 05:12 PM
04/10/09 05:12 PM
mopartial
central PA
Thanks RR. I will try to get my rotors checked. But if it is the front, how come no transmission to steering column?
[Re: mopartial]
#282859
04/10/09 05:40 PM
04/10/09 05:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
A pulsation due to bad front rotors will not always be felt in the steering wheel. There are 3 reasons rotors pulsate.
1. Excessive runout. This can be checked by bolting the rotor to the hub and placing a dial indicator on the surface and watch the needle move as you gently rotate the rotor. It's best to have the caliper off during this check.
2. Parellel variation. This is checked by using a micrometer and measuring the thicknes at multiple points around the rotor. Think of the rotor as a clock face and measure the thickness at each hour mark. This is the most common cuase of a pulsation. The rotor gets thin and thick spots causing the pads to went to travel in and out as the rotor turns. The pulstion gets transmitted back to your foot as the thick point of the rotor comes back around to the pads and pushes them back against the fluid pressure.
3. Badly rusted surfaces. Basicaly the same as #2 but easily seen with no reason to look into the rotor any further.
Warped rear drum brakes will generaly not be felt in the peadal and usually cuases the whole car to feel like it's surging while coming to a stop.
Hope this helps.
I'ld put my $$$ on the rotors.
[Re: RapidRobert]
#282860
04/10/09 05:42 PM
04/10/09 05:42 PM
mopartial
central PA
Hoses are old. I think Id hafta squeeze it mighty tight to occlude psi generated in line. If I ruin hose Ill have another problem on top of the one I have now...
[Re: mopartial]
#282861
04/10/09 05:45 PM
04/10/09 05:45 PM
RapidRobert
We sure dont want to ruin any hoses as we'd be going in the wrong direction here. stay in touch & holler when you find it. If it ain't broke we dont need to be breaking it.
[Re: WILD BILL]
#282862
04/10/09 06:09 PM
04/10/09 06:09 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Warped rear drum brakes will generaly not be felt in the peadal and usually causes the whole car to feel like it's surging while coming to a stop.
Hope this helps.
You forgot hot spots (hard spots on the rotor) that do not wear down evenly with the rest of the drum or rotor as it wears over time. Throw away the rotor if you have these as they cannot be cut out easily and will come back. Most of the time you can see the hard spots on the surface as discolorations that appear to be on the surface, but in some cases you can actually feel them when you run your hand across them.
#282863
04/10/09 06:26 PM
04/10/09 06:26 PM
WILD BILL
BROOK PARK, OH
Hope this helps.
Those would be covered under parallel variation.
[Re: WILD BILL]
#282864
04/10/09 06:35 PM
04/10/09 06:35 PM
mopartial
central PA
Thanks Bill.
So far theres $5 + $$$ riding on my bad rotors... I will probably replace them and pads tomorrow.
...and forever wonder why sometimes a bad rotor makes your steering wheel shimmy and sometimes it doesnt...
[Re: mopartial]
#282865
04/10/09 06:41 PM
04/10/09 06:41 PM
WILD BILL
BROOK PARK, OH
Thanks Bill.
I used to wonder about that sort of thing but it started keeping me up at night so I cut it out.
