440 Milodon Pan Rubbing #2827259
10/01/20 10:06 AM
10/01/20 10:06 AM
Ormond Beach, FL
71STROKERFISH Offline OP
Ormond Beach, FL
Added a stock Milodon 4 qt oil pan and windage tray to my 440 installed in a 70 Superbird. Now, the steering center link rubs the pan. The pan is visibly a bit deeper versus the stock pan. Any thoughts here? Look at the motor mounts and they look ok...
-Dc
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2827270
10/01/20 10:19 AM
10/01/20 10:19 AM
AndyF Offline
AndyF  Offline
Aftermarket parts sometimes don't fit as well as factory parts.
Re: 440 Milodon Pan Rubbing [Re: AndyF] #2827275
10/01/20 10:23 AM
10/01/20 10:23 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A repop “402” pan from Mancini is probably a better fit.
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2827285
10/01/20 10:44 AM
10/01/20 10:44 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
-Dc
Ugh. That's frustrating.
Re: 440 Milodon Pan Rubbing [Re: BSB67] #2827296
10/01/20 11:03 AM
10/01/20 11:03 AM
Ormond Beach, FL
Ormond Beach, FL
I'm planning to get it all the way on the ground and see what it looks like. It's on my friends chassis lift now. I know it wasn't hitting the stock dented pan when I started this clutch, oil pan, windage tray, trans, shock, rear main seal, Dana pinion/cover seal, plugs, valve cover job......LOL! Amazing what needs replaced once its visible and at eye level...LOL!
Tom at Milodon has been pretty helpful and having just talked to him, he mentioned a motivational apparatus....like a hammer....soo.., I guess we'll see....
Oh, also the rear of the engine is not being supported....so maybe some clearance will be gained when the trans goodies are reinstalled....TBD...
-DC
-dc
2018 Jeep Trackhawk
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2827356
10/01/20 12:30 PM
10/01/20 12:30 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
That was my first thought when you mentioned all the stuff you were changing and YES you must install the trans and crossmember before you worry about the pan hitting the centerlink..
Re: 440 Milodon Pan Rubbing [Re: GomangoCuda] #2827358
10/01/20 12:35 PM
10/01/20 12:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Originally Posted by GomangoCuda
Quote
Uumm....yeh.
Re: 440 Milodon Pan Rubbing [Re: fast68plymouth] #2827384
10/01/20 01:54 PM
10/01/20 01:54 PM
Ormond Beach, FL
Ormond Beach, FL
Yep...Been laboring on this sucker for 2 weeks solo and needed to step back and think about it after last night....Yep...I'll get her squared away and report back...last pan I did I was on my back, in the grass and trans was installed.....and it never leaked.....LOL!!
I cannot wait to feel the new clutch/PP and not hear THROWOUT bearing to howl anymore!
-DC
-dc
2018 Jeep Trackhawk
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2827466
10/01/20 04:13 PM
10/01/20 04:13 PM
AndyF Offline
AndyF  Offline
If you don't have the transmission in the car then all bets are off. Check the oil pan clearance once you have the transmission installed on the correct mount and everything is torqued in place.
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2827755
10/02/20 09:22 AM
10/02/20 09:22 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Agree with the above and would also add that once everything is together and if you still have interference, perhaps adjusting the steering box and idler to lower the center link can gain you clearance without bashing the pan.
Re: 440 Milodon Pan Rubbing [Re: AndyF] #2827925
10/02/20 02:49 PM
10/02/20 02:49 PM
Ormond Beach, FL
Ormond Beach, FL
Doing that for sure!
Thanks!
-dc
2018 Jeep Trackhawk
Re: 440 Milodon Pan Rubbing [Re: TC@HP2] #2827940
10/02/20 03:18 PM
10/02/20 03:18 PM
BDW Online content
BDW  Online Content
How is this done?
Re: 440 Milodon Pan Rubbing [Re: BDW] #2828368
10/03/20 05:47 PM
10/03/20 05:47 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Steering box is easy, you shim it. Shim upper bolts to lower pitman, shim lower bolts to raise pitman.
The idler typically requires reaming or filing to slot the mounting hole to allow the idler to angle up or down. Once desired angle is achieved, you weld a washer to the bracket to lock the location in place.
Re: 440 Milodon Pan Rubbing [Re: 71STROKERFISH] #2828514
10/04/20 07:59 AM
10/04/20 07:59 AM
Minn
SportF Offline
SportF  Offline
Minn
I I am guessing the center link is the same as the early "B" center link (62-65). If so, do you have the center link in backwards? It is sort of shaped line a "U" with the bottom of the "U" which should be pointing forward. Changing it around gets you about a 1/4 to 3/8 inch.
