1968 Roadrunner Steering Upgrade #2826979
09/30/20 03:31 PM
09/30/20 03:31 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi Everyone,
Switching the manual steering to power steering on a 68 Roadrunner. Two questions:
1. Will a power steering box from a 70 Cuda work? I heard I would only need to change the pitman arm.
2. Will I need to change the steering column (4 speed on the floor)
Thanks,
Re: 1968 Roadrunner Steering Upgrade [Re: jim6346] #2826984
09/30/20 03:43 PM
09/30/20 03:43 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Correct, I used my manual steering column by cutting the shaft to the proper length and redrilling the hole for the cross pin that engages the coupler at the box.
Re: 1968 Roadrunner Steering Upgrade [Re: Lee446] #2827025
09/30/20 06:10 PM
09/30/20 06:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You will need a power coupler housing.
Re: 1968 Roadrunner Steering Upgrade [Re: NITROUSN] #2827148
09/30/20 10:57 PM
09/30/20 10:57 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Yep, I forgot about that!
