Dual plug reasoning? #2826824
09/30/20 11:05 AM
09/30/20 11:05 AM
cedar rapids, iowa
superhog88 Offline OP
cedar rapids, iowa
Is it absolutely necessary to run dual spark plugs
Can you only fire one plug
Will the engine run properly
Is there a horsepower advantage to two vs one
Re: Dual plug reasoning? [Re: superhog88] #2826953
09/30/20 02:45 PM
09/30/20 02:45 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
dual plugs are mainly for emissions purposes.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Dual plug reasoning? [Re: superhog88] #2827126
09/30/20 09:43 PM
09/30/20 09:43 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The stock coils fire both at the same time, unless you're planning on aftermarket wires/coils?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Dual plug reasoning? [Re: GoodysGotaCuda] #2827240
10/01/20 09:36 AM
10/01/20 09:36 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know there has been people run them on one plug, and even made good power(turbo). I believe they ran them off of a Microsquirt ECU and used an LS coil to fire the one plug. You have to add some hardware to fire the stock coils with that setup. Not a big deal but when your trying to do it as cheap as possible one plug works.
68 Barracuda Formula S 340
Re: Dual plug reasoning? [Re: Bad340fish] #2827249
10/01/20 09:49 AM
10/01/20 09:49 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I am sure one plug would work, I would think two plugs would give you better flame travel and allow you to run less timing.
Re: Dual plug reasoning? [Re: 340Cuda] #2827281
10/01/20 10:34 AM
10/01/20 10:34 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I wanna know how you can fire two plugs at once off of one coil. Spark energy is supposed to follow the easiest path.
How can two plugs both be the easiest path. shruggy
Re: Dual plug reasoning? [Re: John Brown] #2827295
10/01/20 11:03 AM
10/01/20 11:03 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Dual plugs are great in a boosted application.
Re: Dual plug reasoning? [Re: superhog88] #2827354
10/01/20 12:28 PM
10/01/20 12:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Dual ignition promotes engine efficiency by initiating twin flame fronts, giving faster and more complete burning and thereby increasing power".
Aviation piston engines have dual plugs; during the engine run up prior to flight it's SOP to switch off one set of plugs, this produces a noticeable reduction in RPM called a "mag drop".
Re: Dual plug reasoning? [Re: John_Kunkel] #2827428
10/01/20 03:10 PM
10/01/20 03:10 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I can understand dual mags firing two plugs at a time. What I can't understand is one mag or one coil firing two plugs at the same time.
Re: Dual plug reasoning? [Re: John Brown] #2827434
10/01/20 03:16 PM
10/01/20 03:16 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
each coil is actually a dual coil and has its own driver and control from the computer so one coil fires one plug
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Dual plug reasoning? [Re: Jerry] #2827628
10/01/20 09:51 PM
10/01/20 09:51 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
That makes more sense. TY.
Re: Dual plug reasoning? [Re: John Brown] #2827663
10/02/20 12:30 AM
10/02/20 12:30 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The early 5.7 has a coil on one plug and a plug wire from a coil on the opposite side for the second plug. My understanding is the second spark is mostly wasted, firing on the backside of the power stroke. It's purpose is mostly EPA related.
There is apparently a kit to to fire both plugs together.
Kevin
Re: Dual plug reasoning? [Re: superhog88] #2827699
10/02/20 06:12 AM
10/02/20 06:12 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Normally I'd never consider indexing plugs, but I wonder if your return would be greater considering the two plug setup.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Dual plug reasoning? [Re: Twostick] #2827903
10/02/20 02:11 PM
10/02/20 02:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Kevin
Its called don't cross over the wires, just coil up the extra length and stick it in the hole next to the coil. Jacobs makes a short wire specifically for this, probably the "kit" you are thinking of butt it is very easy to do even with the stock wires.
Re: Dual plug reasoning? [Re: superhog88] #2827962
10/02/20 04:29 PM
10/02/20 04:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Very little advantage unless you are trying to light off something hard to light off, lean mixtures, very high compression... Very small HP advantage, very small MPG advantage, very small emmissions advantage, add up all those small advantages and they figured it was worth while.
Re: Dual plug reasoning? [Re: superhog88] #2827964
10/02/20 04:29 PM
10/02/20 04:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Re: Dual plug reasoning? [Re: superhog88] #2828155
10/03/20 01:23 AM
10/03/20 01:23 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Back in 2003 I asked one of the plant engineers (Ram truck plant) why they used the dual plugs and he said it was strictly for emissions.
When they had the crossover plug wires that one fired on the exhaust stroke is what he said.
They got rid of the plug wires after a few years and I believe they just used the computer to do the same thing.
Re: Dual plug reasoning? [Re: SNK-EYZ] #2829756
10/07/20 11:51 AM
10/07/20 11:51 AM
ghinmi Offline
ghinmi  Offline
There's some good and some bad info on this post. Dual plugs are useful in that starting the flame travel from two points burns the mixture quicker. This requires less ignition lead (timing) and does have a power increase associated.
All gen3 hemis fire both plugs in a given cylinder at the same time!!! I'm not sure where people are getting info that one fires during the exhaust but that is not true. 2003-2005 with the crazy spark plug wires use waste spark to fire the plug on a cylinder 360 degrees away. For instance, when #1 is firing, one plug gets lit by the #1 coil and the other plug gets lit by the waste spark off of #6 coil. In 2006 they went to a '2 coils in one box' design and went away from the bundle of plug wires.
The above is why using a short plug wire to hook the coil to both plugs on a 2003-2005 coil is IDIOTIC. You might as well just run one plug at that point because the second plug is doing absolutely nothing for your combustion. The engine will have close to the same power potential as properly firing both plugs but require more timing to do it.
Long story short. If you have an engine management system capable of firing both plugs, do it. If not, don't worry about it but know that your timing numbers will be higher than anything else you see posted online to make the engine happy. And the short spark plug jumper wires are pointless.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Dual plug reasoning? [Re: ghinmi] #2834198
10/18/20 12:24 PM
10/18/20 12:24 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I just added the short wires from Taylor to clean up the engine. This is on a 2005 5.7 in my 64 wagon. I was surprised that the engine revs higher at startup than it did before the short wires. It settles into the same idle after startup. Any ideas for the higher revs on startup now?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Dual plug reasoning? [Re: rattler] #2835616
10/21/20 01:19 PM
10/21/20 01:19 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
There are several big power turbo builds running 1000+ hp using one plug.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
