Page 1 of 4 1 2 3 4
The best Rear main Seal for a 440? #2826476
09/29/20 02:17 PM
09/29/20 02:17 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
I've heard the Mancini rear main seal kit is the best. Is this true? What would you recommend for a stock 440 rear main seal?
Re: The best Rear main Seal for a 440? [Re: Fasbird] #2826489
09/29/20 02:53 PM
09/29/20 02:53 PM
AndyF Online content
AndyF  Online Content
A stock crank should be knurled. That is always the first thing to look at. The other thing to pay attention to is if the rear main is currently leaking. Leakers sometimes are due to poor machine work and those can be hard to fix. Leaking caused by worn out parts can usually be fixed.
Re: The best Rear main Seal for a 440? [Re: AndyF] #2826511
09/29/20 03:57 PM
09/29/20 03:57 PM
Penna
70satelliteguy Offline
Penna
I have been using the billet Mancini seal for the past few years.
I still have leakage!
Mike
Re: The best Rear main Seal for a 440? [Re: 70satelliteguy] #2826520
09/29/20 04:15 PM
09/29/20 04:15 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I just built a engine with a billet retainer and viton seal. Leaked like a sive. Replaced
It with stock retainer and a black felpro from the parts store and its dry as a bone.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: The best Rear main Seal for a 440? [Re: AndyF] #2826534
09/29/20 05:14 PM
09/29/20 05:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
If the crank has stock knurling, isn't it required to use a rope seal? Smooth crank surface gets a Viton or other material.
I thought the knurling would wear away a rubber seal quickly work
Re: The best Rear main Seal for a 440? [Re: Fasbird] #2826540
09/29/20 05:30 PM
09/29/20 05:30 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have the billet Mancini rear main and it doesn't leak a drop of anything.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: The best Rear main Seal for a 440? [Re: OhioMopar] #2826588
09/29/20 07:16 PM
09/29/20 07:16 PM
New York, USA
Chargerfan68 Offline
New York, USA
I have one that just got dyno time only. No leak at all. Then, one that leaks quite a few drops after a drive (my buddies car). Both billet seal retainers.
Re: The best Rear main Seal for a 440? [Re: 68 HEMI GTS] #2826660
09/29/20 09:16 PM
09/29/20 09:16 PM
work shruggy
Edited, I have had less leaks with a stock seal holder than with the race blocks and their brand seal holders shruggy work
I keep the stock seal holder when I destroy or get a customer block in that is not savable up They work really good up scope wrench
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2826758
09/30/20 08:12 AM
09/30/20 08:12 AM
an8sec70cuda Offline
I always use normal Fel-Pro replacement rear main seal and the factory retainer. No issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: The best Rear main Seal for a 440? [Re: an8sec70cuda] #2826760
09/30/20 08:23 AM
09/30/20 08:23 AM
Penna
Penna
How many of the "no leak" rear mains also use a vacuum pump or header e-vac ???
Re: The best Rear main Seal for a 440? [Re: 70satelliteguy] #2826773
09/30/20 09:01 AM
09/30/20 09:01 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
383/432 Stroker that I built four years ago - Zero drips - Street motor - Factory PCV and Three Nipple Breather 1971
I also use the Mancini Billet - Brown Viton Seal - Second motor that I built with great results
Seal clocked at 6 and 12 for me anyways helped align the retainer using those alignment studs
O rings on side of retainer with a little Permatex Black RTV
If I was buying today
I would probably look at Hughes Engines Retainer Kit - They have a pressure relief area built into the retainer like the factory unit
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: The best Rear main Seal for a 440? [Re: 70satelliteguy] #2826776
09/30/20 09:03 AM
09/30/20 09:03 AM
I have 3 of my own here...one has a vacuum pump. The other 2 just have breathers on the valve covers. Never been a fan of the header evac setups.
CHIP
Re: The best Rear main Seal for a 440? [Re: 68 HEMI GTS] #2826782
09/30/20 09:16 AM
09/30/20 09:16 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had the samr results on a 520 ci.rb shruggy
Re: The best Rear main Seal for a 440? [Re: Fasbird] #2826825
09/30/20 11:06 AM
09/30/20 11:06 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
We're jinxing ourselves even talking about this stuff. This discussion alone causes leaks. It's not good to talk about it.
I've only used the ones from old MP kits and Fel Pro kits.
They have all had a number molded into them: 4227926. I had to look really closely to see it.....(It's not hard to guess whos tooling they came from).
Avoiding snafus during install + the side seals seem to cause alot of problems.
Though the white "swells up when soaked in mineral spirits" side seals never really
gave me any trouble, I always thought they were a pain to install and I used up my last pair several years ago on a 440 re-ring.
don't believe they are made anymore (were they asbestos or something?).
So on a modern build, myself I substitute RTV for the side seals. I try to inject it inside the groove
as much as possible and also pack that area using putty knife/fingers and so on.
Rich H.
Esse Quam Videri
Re: The best Rear main Seal for a 440? [Re: DrCharles] #2826851
09/30/20 12:10 PM
09/30/20 12:10 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
If I remember right, the new seals don’t align over the knules, it’s on the smooth part. They have to installed in the right direction too, bevel points into the engine, like a timing cover seal. And the retainer goes on DRY no oil film, sealer will not stick to oil. The whole area is sprayed down with disc brake cleaner.
Re: The best Rear main Seal for a 440? [Re: cudaman1969] #2826924
09/30/20 02:05 PM
09/30/20 02:05 PM
I have used a thin layer of adhesive silicone on the back side to hold the seals to block and seal holder and i ALWAYS use wheel bearing grease on the lip edges of the seal and on the main seal area of the crank surface up
I have never tried installing the seals and crank dry, NEVER twocents
Re: The best Rear main Seal for a 440? [Re: ZIPPY] #2827014
09/30/20 05:50 PM
09/30/20 05:50 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
iagree haha
Quote
I did that on my current 451 and it worked perfectly. I just made sure to get the seal holder and the block operating-room clean before applying it. up
Re: The best Rear main Seal for a 440? [Re: DrCharles] #2827085
09/30/20 08:48 PM
09/30/20 08:48 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I just bought and installed the Mancini rear main seal, and it solved my leak issue.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: The best Rear main Seal for a 440? [Re: BloFish] #2827092
09/30/20 09:00 PM
09/30/20 09:00 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Me too. Customer had a bad leaker on his motor. It was a fresh rebuild that had cam and piston problems. Just finished it about two weeks ago. No more leaks with the Mancini seal. I also bought the extra cost orange seal with the billet cap.
Re: The best Rear main Seal for a 440? [Re: fastmark] #2827096
09/30/20 09:08 PM
09/30/20 09:08 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Page 1 of 4 1 2 3 4
