Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2115140
07/21/16 10:00 PM
07/21/16 10:00 PM
AndyF Online content
AndyF  Online Content
This is what I did for my car. I use these tie downs for the chassis dyno. The front brackets I make will also fit on the rear of the car if you prefer to tie down the body rather than the suspension.
Re: rear shock plate with integrated tie down loop [Re: AndyF] #2115348
07/22/16 09:27 AM
07/22/16 09:27 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
I did buy two sets of yours for my bee but couldn't find a good spot to attach them to on the rear of the car. I didnt't see the shock plate mount pictured above. That looks like a nice piece as well.
Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2115367
07/22/16 10:33 AM
07/22/16 10:33 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Here's mine. Overkill? probably but I don't want my car tied to a flimsy piece of sheet metal.
Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2115420
07/22/16 11:50 AM
07/22/16 11:50 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you use the AR brackets in the front(attached to a bumper bracket bolt) you are tying down the "body".(no suspension movement) If you use the shock plate anchor in the back, you are tying down the suspension.(suspension free to move) Is there going to be an issue with the front suspension being held tight but the back suspension being free to move? Shouldn't it be one or the other...not different front to back? I'm not a very experienced tower. Not trying to stirthepot it's an honest question.
Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2115424
07/22/16 12:01 PM
07/22/16 12:01 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've always used axle straps on the rear end and hooked into the k member in the front and never had any issues.
Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2115691
07/22/16 06:50 PM
07/22/16 06:50 PM
I think you can use one of the bolts that holds the bumper bracket to the frame. At least that worked on my '65 Coronet but it might not work on a new car.
Re: rear shock plate with integrated tie down loop [Re: kbcuda] #2116486
07/24/16 04:09 AM
07/24/16 04:09 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I drove a flatbed tow truck for 5 years and fastened down cars all the ways mentioned above and some other ways too.
Sometimes we are towing wrecks, exotics, old cars and new cars/trucks. There are quick methods, easy, proper and improper methods to secure a car. Sometimes there are no accessible anchor points and you have to be creative.
As noted by Challenger, it's a comforting feeling to have your cargo secure and not moving around but after towing thousands of cars I've developed an opinion for how I'd tow MY OWN CAR.
There were thousands of tows where I secured to the frame. If the road is smooth it was okay but if there was any bumps or dips in the road. Big enough to compress the towed car's suspension, not a problem. The suspension compresses and the strap become slack. Now the problem, the suspension extends up to the point where the straps limits the travel and it hits them like a solid stopper.
I know most car trailers are not equipped for the BEST method but if you look at the latest car transport trucks you will see. Securing the tires is the best method.
Re: rear shock plate with integrated tie down loop [Re: Magnum] #2823671
09/22/20 03:39 PM
09/22/20 03:39 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I know this is an old thread, but I'm looking for something available that would bolt to the rear leaf spring U-bolts under shock plate .... for hooking up to trailer straps for open trailer towing. Anything from a vendor available?.. for my E-body?
I'll be changing my leaf springs very soon and this could be the time to do it. Wrapping short straps around my axle didn't seem to be very good (diagonal from behind the rear brakes using ~24" straps).
Also, the factory rear frame anchors have their holes a bit too small, but snap hooks could be used there.
I wonder which is better... hooking up the axle.. or the rear chassis?
I don't tow much.. but intend to start up again for 2021... towing maybe 6x per year midwest.
T/Anks ahead.
Re: rear shock plate with integrated tie down loop [Re: Mopar Mitch] #2823690
09/22/20 04:10 PM
09/22/20 04:10 PM
Yeah this thread is 6 years old so things have changed. There is at least one vendor who makes a sandwich type of hold down, I know I've seen those parts advertised on here recently. I redesigned my rear shock plates so now everything I build has built in tie down loops like this.
Re: rear shock plate with integrated tie down loop [Re: AndyF] #2823858
09/22/20 09:40 PM
09/22/20 09:40 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Rear laser cut trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price.
Email mrrandyj@aol.com
mrrandyj member here listed in b body 1970 back
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: rear shock plate with integrated tie down loop [Re: 1969gtx] #2824166
09/23/20 03:32 PM
09/23/20 03:32 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Thanks for the replies... Andy and 1969GTX
Re: rear shock plate with integrated tie down loop [Re: AndyF] #2824242
09/23/20 06:18 PM
09/23/20 06:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Andy, that solution has KISS look to it. up
I asked the member here with the "sandwich" solution if he wouldn't mind making up a few sets for my projects out of Ti, albeit at a greater acceptable material cost.
Never agreed on a deal. bawling
Re: rear shock plate with integrated tie down loop [Re: jcc] #2824442
09/24/20 08:54 AM
09/24/20 08:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Re: rear shock plate with integrated tie down loop [Re: 340Cuda] #2825985
09/28/20 11:24 AM
09/28/20 11:24 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I took off the shock plates and welded this to them.
Re: rear shock plate with integrated tie down loop [Re: AndyF] #2826300
09/28/20 11:39 PM
09/28/20 11:39 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Andy, how much for a set of those?
Re: rear shock plate with integrated tie down loop [Re: Jim_Lusk] #2826381
09/29/20 10:06 AM
09/29/20 10:06 AM
BDW Offline
BDW  Offline
There’s plenty of thread on the U-bolts, why not add a simple L-bracket on the bottom?
Seems like you could get something for a couple of bucks at any HW store.
Re: rear shock plate with integrated tie down loop [Re: BDW] #2826441
09/29/20 12:54 PM
09/29/20 12:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think the advantage of the other vendor "sandwich" design is the spreading the bending/shearing loads fairly equally to all four bolts, which likely are quite adequate, but never intended to be loaded as such. A single bolt might be problematic in an accident impact restraint situation. Case of doable, but it is adviseable?
Andy's design effectively offers the same advantages with less parts.
Re: rear shock plate with integrated tie down loop [Re: Jim_Lusk] #2826492
09/29/20 02:58 PM
09/29/20 02:58 PM
Mancini Racing charges $100 for the race style, the street style is around $85. https://www.manciniracing.com/marashplset.html
Re: rear shock plate with integrated tie down loop [Re: jcc] #2826497
09/29/20 03:04 PM
09/29/20 03:04 PM
I also add a jack stand support when I build them. I weld the rear flange to the side flange in order to box in the part. The jack stand support is welded on the bottom and to the rear flange to add additional support. I bend a tab up in the jack stand support to keep the jackstand from sliding out of place.
Re: rear shock plate with integrated tie down loop [Re: AndyF] #2826502
09/29/20 03:30 PM
09/29/20 03:30 PM
I'm not a fan of the tie down metal hooking onto the metal on the car hold downs due to wear and potentially causing stress riser in the hold own metal work
I've hauled and towed a bunch of different cars starting back in the old days with a tow bar on the race car, once only, and open trailers and open ramp trucks and then enclosed truck and trailers. I used a 1/2 ton come along(small ratchet hoist) with chains to hold the other end of the car and then ratchet tie downs with straps. I prefer the straps and ratchet tie downs, one on each corner, to wrapping a chain onto some part of the car to hold it tsk
I wreck one NHRA Hemi stock car using a 1/2 ton come long in front to hold the car and a small chain wrapped around the rear end housing tied down to the rear of the borrow trailer realcrazy
I had my wife and the driver of that car in the front seat of my 1/2 ton 1960 Ford pickup, I hit a large dog that ran out in front of my truck, it got stuck under the front fender and passenger side front tire making my pick up jack knife and slide off the other side of the road into the ditch, the rear tie down chain broke on the race car allowing it to run over the front tire stops and run up onto the back of my pick up bed and then rolling over onto it tops totaling that car shock whiney The owners of the car had no insurance on it and my insurance didn't cover me hauling "race cars", but it does now up
I have special coverage on all of my toy cars, AKA "Race Cars" which has paid for damages to them at the track when another car ran into it while park behind my trailer up Get you some of that twocents
IHTH
