Rim Blow Switch Removal #2826314
09/29/20 12:36 AM
09/29/20 12:36 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi I'm redoing a rim blow wheel for my Challenger ragtop.
Does anyone know of a clever way to to remove what used to be the switch?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Rim Blow Switch Removal [Re: Hrtbkr] #2829108
10/05/20 10:33 PM
10/05/20 10:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
sounds like the switch is no good, then just peel it off and clean out the channel that it sits in...installing the new one is alot harder
Re: Rim Blow Switch Removal [Re: AARCONV] #2829201
10/06/20 09:28 AM
10/06/20 09:28 AM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I've had switches that come out of the slot/track rather easily and some that were pretty stuck from age and rubber degradation.
There should not have been glue used, if it is original. The switch has a wide spot that tucks into the slot, so should come out.
Start at one end and pull it out. It if is already trash, it doesn't matter. Your priority is to NOT screw up the wheel.
If any pieces and parts are left over, use a very tiny blade screw driver or a dental pick to remove leftover pieces.
The whole channel should be smooth and free from rubber bits.
Re: Rim Blow Switch Removal [Re: RP's R/T's] #2829262
10/06/20 12:16 PM
10/06/20 12:16 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
After 50 or so years, the switch on my wheel had turned into sort of a rubberized concrete. One layer came up easy (about 1/16" worth), but the rest seemed almost permanent.
I ended up using a Dremel with a wire wheel (make sure you do this outside or you'll spend hours cleaning your garage DAMHIK), then digging the rest with an Xacto.
Re: Rim Blow Switch Removal [Re: Hrtbkr] #2833997
10/17/20 07:11 PM
10/17/20 07:11 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I'm just gonna suggest a narrow wood chisel, and patience.
