Differences in shock plates #2826307
09/28/20 11:56 PM
09/28/20 11:56 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Here's some part numbers just so folks can see what I'm talking about.
These all go on 3" tube axles.
3400836 & 837.....Supposedly '70 E-body only (I don't know)
1856346 & 347.....Much more widely used.
The only difference I can see is that with the 836/837, the shock stud is about an inch lower than the 346/347.
Why would 70's need a lower shock mount, is the upper mount also an inch lower ?
Seems like these could all be used interchangeably (unless you just need the correct numbers).
Re: Differences in shock plates [Re: hemienvy] #2826315
09/29/20 12:41 AM
09/29/20 12:41 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, the '70 e-body ONLY were "new" for the new model (possibly to optimize shock travel ??)
the '70 T/A & AAR used the 346/347 ones & all of '71+ E-bodies also (possibly to simplify the parts bin ??)
