ignition harness replacement plug #2825262
09/26/20 11:00 AM
09/26/20 11:00 AM
WASHINGTON
superbee471 Offline OP
WASHINGTON
im looking to buy a replacement plug housing or kit for the dash harness in my 71 Charger. It is the male end attached to the main harness and plugs into the ignition switch plug on the steering column. it is a male 8 pin white plug. all the used ones i have found are burnt , broke or both. is there a supplier of these replacement plugs ? any information on where to buy these new? thanks for looking.
Re: ignition harness replacement plug [Re: superbee471] #2825284
09/26/20 12:12 PM
09/26/20 12:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: ignition harness replacement plug [Re: John_Kunkel] #2825293
09/26/20 12:31 PM
09/26/20 12:31 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I needed one of those.
Re: ignition harness replacement plug [Re: John_Kunkel] #2825861
09/27/20 10:48 PM
09/27/20 10:48 PM
WASHINGTON
WASHINGTON
you could have not told me,
Re: ignition harness replacement plug [Re: John_Kunkel] #2826214
09/28/20 07:13 PM
09/28/20 07:13 PM
WASHINGTON
WASHINGTON
Thank you, i didnt read your reply right the first time, thought you bought the last one. got 4 of them comming. going to have to find out that guys store name and see what else he has. thank you again
Re: ignition harness replacement plug [Re: superbee471] #2826253
09/28/20 08:23 PM
09/28/20 08:23 PM
It's a dry heat
It's a dry heat
Guess, Im should be glad I bought one I needed,,,,I didnt know I needed it
