1970 B Body Ground Wires
#2825732
09/27/20 05:35 PM
09/27/20 05:35 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hi.I have a 1970 Plymouth GTX. It seems to have a bad ground for the lights on the passenger side. This includes the brake light and parking lights. My brother said it should have a ground one on the engine to fire wall. I cannot find a new ground cable or wire. Is there supposed to one on the firewall to the passenger side of the engine? Any help is appreciated.
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: 1970 B Body Ground Wires
[Re: GTXKARL]
#2825742
09/27/20 05:46 PM
09/27/20 05:46 PM
Posts: 21,396 It's a dry heat
gtx6970
It's a dry heat
Is there supposed to one on the firewall to the passenger side of the engine? Any help is appreciated. Nope, body ground is a lead off negative battery cable to radiator support
[Re: GTXKARL]
#2825847
09/27/20 10:09 PM
09/27/20 10:09 PM
Posts: 5,439 So Cal
Sinitro
So Cal
On my 70 RR I had funny ground issues with the lights... My solution was to attach a ground lead from the voltage regulator mount on the firewall back to the engine, I used 1 of the back bolts holding the valley pan. Just my $0.02...
