SSBC Rear Brakes - Replacement Parts #2825614
09/27/20 12:28 PM
09/27/20 12:28 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Looking at getting some ideas on where to find replacement parts for my SSBC rear brake kit. I believe this is the A155 kit. The site says "D347" brake pads and they look like the ones I have. My rotors are cast with "86730".
Can anybody confirm the application I can use for sourcing the pads/rotors? I don't want to go through SSBC and pay premium money if parts house parts will do.
Thanks! thumbs
Re: SSBC Rear Brakes - Replacement Parts [Re: cjskotni] #2825623
09/27/20 12:43 PM
09/27/20 12:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks! thumbs
The original SSBC is out of business frown
There is purportedly a new company that bought the assets LINKY TO NEWSSBC WEBSITE
They should be able to tell you the original application for the pads/ rotors. The rotor may be a "special" app though shruggy
I believe Summit is still offering their kits so the may be able to help as well
To answer your question the D347 when googled pops up in multiple locations. beer
Re: SSBC Rear Brakes - Replacement Parts [Re: TJP] #2825711
09/27/20 04:45 PM
09/27/20 04:45 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
It appears that the calipers/pads in this kit fit a late 80's/early 90's Ford Thunderbird. I went ahead and ordered a new set of Bendix ceramic pads and had the rotors turned down 5 thousandths on each side to take of the grooves out. I am not a big fan of turning rotors but these are rear brakes and I am hoping the small amount taken off won't be an issue.
Re: SSBC Rear Brakes - Replacement Parts [Re: cjskotni] #2825751
09/27/20 06:04 PM
09/27/20 06:04 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i run these as well and the parking brake calipers came off the early 90s ford thunderbird. along with the rotors
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: SSBC Rear Brakes - Replacement Parts [Re: Jerry] #2825758
09/27/20 06:38 PM
09/27/20 06:38 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
My rotors don't match what I saw of the Thunderbird parts. The rotor hats seem deeper on mine. Pads and calipers seem to be a match.
Re: SSBC Rear Brakes - Replacement Parts [Re: cjskotni] #2825782
09/27/20 07:23 PM
09/27/20 07:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
.005 a side is equivalent to zero. They'll be fine. If you spend some time digging the are several forums that list purported sources of the rotor. However the general consensus appears to be that SSBC re-drilled the bolt pattern beer
Re: SSBC Rear Brakes - Replacement Parts [Re: TJP] #2825903
09/28/20 04:22 AM
09/28/20 04:22 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Turning rotors is a regular mechanical and mantenience proceedment. Hence the reason why they get the minimum thickness rate casted or stamped somewhere. You don't have to worry ( even less for that ammount ). Even less on a car is not a driver.
