Re: Mounting a fuel pump
[Re: moparx]
#2825312
09/26/20 01:12 PM
09/26/20 01:12 PM
Posts: 4,670 On the parachute mount
n20mstr
I have a 5 gal. Cell in the spare tire well . It’s elevated so the outlet is level with the pump which is mounted behind the cell
....BAD A$$ STREET CAR.....
[Re: topside]
#2825337
09/26/20 02:26 PM
09/26/20 02:26 PM
Posts: 20,147 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used a holesaw to put a hole in my trunk so I could mount the pump on my frame and the top of the pump is in the trunk. Worked out great.
[Re: pittsburghracer]
#2825370
09/26/20 05:08 PM
09/26/20 05:08 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I used a holesaw to put a hole in my trunk so I could mount the pump on my frame and the top of the pump is in the trunk. Worked out great. That is how mine was in the first evolution. Just the top of the pump protruded into the trunk , using a sumped stock tank. Made a simple bracket to bolt it to the outside of the spare tire well.
[Re: AndyF]
#2825384
09/26/20 06:04 PM
09/26/20 06:04 PM
tubtar
St. Paul , Mn.
I really like the new pumps that bolt inside the fuel cell. Holley has a line of them and so do other vendors such as Aeromotive. Just a whole drop in assembly. The chassis builder that I work with has started to move all the drag cars over to that style since it works so well and it frees up a bunch of space and gets rid of some plumbing. That is what I am looking at for my current project. Even in a carburated application , it makes sense. And is as clean a look as you can get.
[Re: mopar dave]
#2825542
09/27/20 07:59 AM
09/27/20 07:59 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
My car has the stock tank with the spare tire well removed. There is a ton of space under there with the tire well removed. I have two fuel pumps, a fuel cooler, and a trailer hitch setup all between the tank and the rear valance.
EDIT, I didn't see your picture. Looks like you already used that room haha.
68 Barracuda Formula S 340
#2825669
09/27/20 02:44 PM
09/27/20 02:44 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
I used a holesaw to put a hole in my trunk so I could mount the pump on my frame and the top of the pump is in the trunk. Worked out great. This is a simple solution to your problem.
[Re: Al_Alguire]
#2825674
09/27/20 03:00 PM
09/27/20 03:00 PM
Posts: 10,019 MN
JERICOGTX
MN
Mine is mounted next to the fuel cell. My cell is raised so it’s above the trunk floor.
69 GTX
68 Road Runner
[Re: mopar dave]
#2825818
09/27/20 08:30 PM
09/27/20 08:30 PM
Posts: 20,147 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Didn't know it was safe to put them in the trunk. Mounting mine like I did I knew immediately when I had a fuel leak as it leaked on the ground. I removed it that week and fixed it. How fast are the guys mounting them in their trunks going to find it.
