Re: ABS brakes
[Re: pitalplace]
#2824772
09/24/20 10:03 PM
09/24/20 10:03 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
I've eliminated the abs brakes on a couple projects with no ill effects. We have put over 60,000 miles on my 48 Plymouth coupe that I eliminated the ABS from. I ran the rear line directly to the rear hose and then replaced the hard lines across the axle to the wheel cylinders. Then I removed anything ABS related. That was with a 1990 harness, everything ABS was pretty much stand alone. I suspect when you get into the newer models, eliminating the system may still get you a dash light (that you can pull the bulb out of). I'm using a 96 Dakota donor with ABS on my current project. This one has the full on 4 wheel system, one would have to redo all the brake lines on this one. Its going to be a 4x4 used during the winter, I'm thinking I'm keeping this ABS system. I can tell you that through those 60K miles, there were a few times I wished the ABS still worked, but for the most part, I haven't missed it. Gene
Re: ABS brakes
[Re: pitalplace]
#2826584
09/29/20 07:10 PM
09/29/20 07:10 PM
Posts: 3,428 Dandridge TN
Dabee
Dandridge TN
Thank you Gene for the answer. I would not be able to hook the wiring to the 1976 axles so I was thinking that is the way to go. I was not sure if I could eliminate the wiring. Do you think a dakota heating/ air conditioning unit would fit under the dash of the 1934? I would like to just be able to plug in the wiring. Again Thanks for your help Byron Tried that in my 55 Dodge truck. No room for it. I used a classic air minni II. It fit and still works great after 52,000 miles.
