Re: 360 Magnum into 87 Ramcharger
[Re: crowbait]
#2824776
09/24/20 10:11 PM
09/24/20 10:11 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Water pump if going back to v belts. Fuel pump or swap front cover. You can't just change the water pump, you have to change the front cover as well because not only is the bolt pattern different, the depth of the cover is different as well. You can get a snout extension kit from Hughes to put a fuel pump eccentric on the short snout magnum cam. Now if any of your LA drive accessories bolt to the cylinder heads you will need to address that as well because the bolt bosses are not the same. It's best to just add an electric fuel pump and leave all the magnum accessories in place.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: JDMopar]
#2824813
09/25/20 01:19 AM
09/25/20 01:19 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
Or, He could just skip all this nonsense swapping parts and feeding a money pit and just get the RH/RE overdrive that belongs to it (+5 mpg) and grab the computer that belongs to it. Turn the key, go, and enjoy the win/win.
Mo' Farts
Moderated by "tbagger".
