Help Identify wire on 74 RC Forward Light Harness #2823850
09/22/20 09:27 PM
09/22/20 09:27 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm in the process of re-wiring my Ramcharger (should be done tomorrow)
The wiring harnesses (all of them, from front to back) I removed from a 1974 W200 with Factory A/C due to the fact that the harnesses in the 74 Ramcharger were not only not correct for the year, but hacked and damaged beyond repair.
On the forward light harness, the A/C Compressor clutch has this wire that comes off of it to engage the clutch. Since it was missing it's end, I removed the end off of the harness that was in the Ramcharger and put it on this one. It also has this other jumper with a light blue wire in it that has a fiberglass shield around it. Any idea of what it could be for?
I couldn't find anything in the Factory Service Manual and I don't think I'm missing anything but I'm still a few weeks from making a shake-down cruise.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Help Identify wire on 74 RC Forward Light Harness [Re: shanker] #2823869
09/22/20 10:23 PM
09/22/20 10:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A/C pressure switch that feeds the clutch power.
Re: Help Identify wire on 74 RC Forward Light Harness [Re: stumpy] #2824027
09/23/20 12:15 PM
09/23/20 12:15 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
Nice....The Low pressure switch never crossed my mind. No hoses are on the truck at the moment so I didn't even look for it.
