Re: Electric oil pump engine pre luber
[Re: hemienvy]
#2823543
09/22/20 09:30 AM
09/22/20 09:30 AM
Posts: 11,998 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have an Accusump on the Cuda that I use as a pre-luber. It fully pressurizes the oiling system prior to firing it up. What advantage is there to using an electric motor rather than air pressure to do that?
Master, again and still
[Re: DaveRS23]
#2823560
09/22/20 10:26 AM
09/22/20 10:26 AM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
What advantage is there to using an electric motor rather than air pressure to do that? The electric unit uses the oil in the pan - that's why it needs a motor. So you're not carrying around a big bulky reservoir with an extra 3 quarts or so of oil in it. I suspect that an accusump with solenoid, etc will be about the same price as the electric system.- but takes up WAY more space and weighs a lot more.
[Re: Stanton]
#2823830
09/22/20 08:45 PM
09/22/20 08:45 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What advantage is there to using an electric motor rather than air pressure to do that? The electric unit uses the oil in the pan - that's why it needs a motor. So you're not carrying around a big bulky reservoir with an extra 3 quarts or so of oil in it. I suspect that an accusump with solenoid, etc will be about the same price as the electric system.- but takes up WAY more space and weighs a lot more. I understand the differences. My point was that both approaches would do the same job of pre-luber if properly set up. Each with it's own pluses and minuses. I guess there could be applications where every square inch and every once is more important than 3 extra quarts of oil capacity. Frankly, I wasn't aware of that.
[Re: DaveRS23]
#2826308
09/28/20 11:58 PM
09/28/20 11:58 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Exa-Pump by Turbowerx
Edit: sorry, pic rotated 90* left, and is hard on the eyes.
[Re: thehemikid]
#2826486
09/29/20 02:47 PM
09/29/20 02:47 PM
Posts: 11,501 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I am in favor of using something to prelube a race engine to begin the day, whether it has been sitting for a day or a month. Either an electric pump, mechanical pump that can be spun with a drill motor, or an accusump. Spinning the engine with the starter to get pressure kind of defeats the reason for doing it.
I prefer the accusump with an electric valve because it can also be used to protect the engine should the oil get away from the pickup due to g-forces on accel or deccel
