Cutting cast iron #2822651
09/19/20 03:53 PM
09/19/20 03:53 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I need a section off of a broken block, can I cut with an oxy-acetaline torch? I would cut a much larger section then grind it down to fit.
Can’t get to it with a grinder or saw
Re: Cutting cast iron [Re: cudaman1969] #2822656
09/19/20 04:32 PM
09/19/20 04:32 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Years ago (a lot of years ago!) I tried cutting a Chevy three speed transmission housing with a gas torch. As I recall, it worked but wasn't pretty. Just throwing this out, have you considered a plasma torch?
Re: Cutting cast iron [Re: 6PakBee] #2822670
09/19/20 05:10 PM
09/19/20 05:10 PM
fredericksburg,va
fredericksburg,va
My next choice but I’ll have to buy one
Re: Cutting cast iron [Re: cudaman1969] #2822671
09/19/20 05:11 PM
09/19/20 05:11 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I would think a plasma cutter would make a cleaner cut.
Re: Cutting cast iron [Re: cudaman1969] #2822703
09/19/20 07:19 PM
09/19/20 07:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Would a sawzall work ?? Pic's or a description of the area you're after would help beer
Re: Cutting cast iron [Re: TJP] #2822715
09/19/20 07:59 PM
09/19/20 07:59 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
While you can cut cast iron with a plasma cutter torch, or any torch.it is not the best method to cut cast iron, due to cast poor Iron content.
When cutting cast iron, it is best to use a snap cutter, angle grinder, or reciprocating saw.
My Monster are real!
Living within your means makes life pretty easy.
Re: Cutting cast iron [Re: 67vertman] #2822732
09/19/20 08:48 PM
09/19/20 08:48 PM
fredericksburg,va
fredericksburg,va
Cutting out a part of the cylinder in the bottom of the cylinder inside the crankcase to weld back into another block
Re: Cutting cast iron [Re: cudaman1969] #2822737
09/19/20 09:00 PM
09/19/20 09:00 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Maybe something like this?
Angle Cutter
Re: Cutting cast iron [Re: 6PakBee] #2822750
09/19/20 09:29 PM
09/19/20 09:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd use a .030 or .060" cut off wheel on a 4 1/2" grinder.
Re: Cutting cast iron [Re: justinp61] #2822774
09/19/20 10:37 PM
09/19/20 10:37 PM
fredericksburg,va
fredericksburg,va
I thought of one of those chainsaw type cutters they use in the wrecking yards and rescue trucks too. The piece is right up into the cam area
Re: Cutting cast iron [Re: cudaman1969] #2822776
09/19/20 11:03 PM
09/19/20 11:03 PM
What kind of block are you trying to fix?
Re: Cutting cast iron [Re: cudaman1969] #2822818
09/20/20 08:35 AM
09/20/20 08:35 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If you can find someone who is capable of making this repair then he will know how to cut out the part you need. Note the word if at the beginning of my post. That is going to be a very difficult repair in cast iron. Is this block super rare and unobtainable?
Re: Cutting cast iron [Re: Cab_Burge] #2822859
09/20/20 10:44 AM
09/20/20 10:44 AM
fredericksburg,va
fredericksburg,va
Hemi and rare. My fire pit is made to get to the proper temp, I have the proper rods and the skill, I will fix this. The ‘piece’ will be from a broken Hemi block so the same composition. I’ll try the sawsall first, just a lot has to be removed first
Re: Cutting cast iron [Re: cudaman1969] #2822945
09/20/20 03:15 PM
09/20/20 03:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'd avoid cutting grey cast iron with a torch. From my metallurgy classes back in college, I seem to remember something about that converting grey cast iron into brittle white iron. That is why special rods are needed for welding cast iron.
Floyd Lippencott IV
Re: Cutting cast iron [Re: mr_340] #2822978
09/20/20 05:08 PM
09/20/20 05:08 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Air arc.
Re: Cutting cast iron [Re: cudaman1969] #2823048
09/20/20 08:25 PM
09/20/20 08:25 PM
I would try to do the job with a 4 inch O.D. abrasive cut off wheels, as many as needed up
Take your time and bring a lot of patience twocents wrench thumbs
Re: Cutting cast iron [Re: Cab_Burge] #2823078
09/20/20 09:28 PM
09/20/20 09:28 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Cut it with a reciprocating saw if you intend to weld the cut piece into something else. Cutting with either a torch or a plasma cutter is going to give you a cut edge that probably won't weld well.
How do you intend to seal the water jacket of the motor once you cut and weld it back together? If its the bottom of a cylinder your trying to repair, wouldn't a sleeve work much better, or is that big of a chunk broke out? Gene
Re: Cutting cast iron [Re: poorboy] #2823143
09/21/20 03:08 AM
09/21/20 03:08 AM
fredericksburg,va
fredericksburg,va
Getting to hot on the cut worried me too, reason I asked. To answer a few questions there’s a good size hole in the bottom of the cylinder (that someone tried to fix before I got it, a wire welder no less) and it will get a sleeve after. Block will be brought up to around 600-800 degrees, welded, then covered with the coals for a long cool down (the secret for no cracks). Then pressure checked for leaks and magged for cracks. Actually got two welds in that cylinder, a vertical crack from bottom to within an inch of the deck opposite the hole.
Block has all the right numbers
Re: Cutting cast iron [Re: cudaman1969] #2823190
09/21/20 09:52 AM
09/21/20 09:52 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Boy, that sounds like a block I ran into at one time. Crack in bore, attempted repair with a MIG, other damage. Here are some photos I took before the seller got the block back.
Re: Cutting cast iron [Re: 6PakBee] #2823382
09/21/20 05:51 PM
09/21/20 05:51 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Floyd Lippencott IV
