motorhome 440 block, any head gasket issues?
#2823257
09/21/20 12:47 PM
09/21/20 12:47 PM
RapidRobert
there was something about different cooling holes/special gasket. some where down the line I would use it with likely some alum stealth heads. problem or no problem? thank you for your time.
Re: motorhome 440 block, any head gasket issues?
[Re: RapidRobert]
#2823298
09/21/20 01:51 PM
09/21/20 01:51 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
The 440-3 motor home blocks had the extra cooling holes them, the non 440 motorhome and pickup truck motors did not have them Those extra holes are on the motor mount side of the block between the bottom head bolt holes, I built a motor home block with them and used a set of 906 heads with head gaskets with no holes in them for the extra cooling and it ran fine in my old bracket Duster, not the street and strip Duster The extra cooling was for the exhaust valves in those motors due to pulling long grades at a steady RPM making a lot of heat in the cooling systems
[Re: fastmark]
#2823549
09/22/20 09:49 AM
09/22/20 09:49 AM
RapidRobert
are you thinking I should be OK with the new(er) gasket?
[Re: fastmark]
#2823634
09/22/20 02:11 PM
09/22/20 02:11 PM
RapidRobert
thanks bro I'll give it some more thought but it sounds like I had better use a regular block & take no chances as time/moneywise it could be disasterous
[Re: RapidRobert]
#2823705
09/22/20 04:54 PM
09/22/20 04:54 PM
Cab_Burge
thanks bro I'll give it some more thought but it sounds like I had better use a regular block & take no chances as time/moneywise it could be disasterous If your worry about the cooling holes leaking around the head gasket how about drilling and tapping them for 1/16 NPT pipe plugs
[Re: Cab_Burge]
#2823813
09/22/20 08:18 PM
09/22/20 08:18 PM
RapidRobert
good info. I think I can deal with it now
[Re: RapidRobert]
#2824305
09/23/20 08:59 PM
09/23/20 08:59 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
If the extra cooling holes are the 8 per side between the lower head bolts, they are to cool the spark plugs on heads with the small peanut spark plugs. I have used the blocks with no issue. The felpro 1009,17059, and 8519pt that I have here, have the holes. If your block has a big bore chamfer 1009 will not work. Hemis may have those cooling holes but they also have larger slots in the upper row of cooling slots, early bigblocks also had wider slots. I make the slots a little wider, but am not going to say you should. Call 440 souce and see if you can drill the heads, I can say for sure you can drill an early block to use the motorhome heads but have never went the other way, I would not try, as the hole is angled, so I made the slot a little bigger, good luck.
[Re: 4406bbl]
#2824309
09/23/20 09:08 PM
09/23/20 09:08 PM
4406bbl
Nebraska
One other thing, sonic check the block, that way you know it is not thin causing overheating, we know stealth heads do not run hot on normal engines, so that gets you down to the head gasket, or a water pump or housing issue. I can't remember if that was the block where 1/2 of the front water pump housing outlets were blocked, cast shut, I know I ground that out but has been 30 years, and I grind everything, for better or worse.
