Re: Redrilled m1 magnum intake. Junk?
[Re: Pacnorthcuda]
#2823220
09/21/20 11:36 AM
09/21/20 11:36 AM
Posts: 20,200 Park Forest, IL
slantzilla
Park Forest, IL
If that hole is the only thing wrong, tap it and plug it.
[Re: slantzilla]
#2823249
09/21/20 12:41 PM
09/21/20 12:41 PM
Posts: 19,529 north of coder
moparx
all those holes look like they could be tapped for tapered pipe plugs, providing of course, they are somewhat close to the hole size of "??" required for "??" pipe thread. example, drill size for 1/4" NPT is 7/16". you could then use square head aluminum pipe plugs with a good sealant [JB weld perhaps ?], then cut/grind the plug[s] flush with the casting surface. lots of work involved though, to do this. hopefully, you didn't pay much for that intake. unless, of course, you want/decide to use it on an LA block.
[Re: moparx]
#2823255
09/21/20 12:46 PM
09/21/20 12:46 PM
Posts: 10,741 North Dakota
6PakBee
North Dakota
I would think that Mr. TIG is your friend.
[Re: IMGTX]
#2823276
09/21/20 01:10 PM
09/21/20 01:10 PM
RapidRobert
^^^ might of added it for an aftermarket water temp gauge (& wanting to keep the OE one)
[Re: elmor353]
#2823578
09/22/20 11:06 AM
09/22/20 11:06 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
The hole in the water passage is for a mechanical temp gauge sender. Pretty common, but there isn't a lot of material there so be careful if you plan to use it or plug it with a pipe plug.
[Re: 6PakBee]
#2824080
09/23/20 01:28 PM
09/23/20 01:28 PM
moparx
I would think that Mr. TIG is your friend. correct. but does the OP have one, or know how to weld aluminum ? if he has to send that intake out, it may cost more to repair those holes than it is worth.
[Re: moparx]
#2824385
09/24/20 12:37 AM
09/24/20 12:37 AM
Posts: 5,948 British Columbia
chrisf
British Columbia
I would think that Mr. TIG is your friend. correct. but does the OP have one, or know how to weld aluminum ? if he has to send that intake out, it may cost more to repair those holes than it is worth. no problem there. but like you say. might not be worth the effort for a $100? (maybe?) intake
[Re: chrisf]
#2824859
09/25/20 09:24 AM
09/25/20 09:24 AM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
By the looks of those holes it looks like it was factory drilled and he just hogged the lower portion out. Just weld a threaded fitting in the water port or plug weld it.
