What sensor did I break on wife's '01 Chry T&C
#2822768
09/19/20 10:27 PM
09/19/20 10:27 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Working on my wife's 2001 Town and Country 3.8 V6 when I spotted a broken sensor(?) in the block, back firewall side below the take down exhaust tube. I know its been broken for a while but everything seems to function correctly.....for the most part. No codes, gauges seem okay, starts, runs, idles. Kind of not important (to me) at the moment as I was in the middle of replacing the power steering rack and the upstream 02 sensor (which is stripped or cross threaded ) and the downstream 02 sensor both taken out by the groundhog along with two spark plug wires, The PS rack replacement is a major PIA. Thanks in advance and here are the sensor photos and location. Though it might be a crankshaft sensor or temp sensor of some kind but can't find anything that looks close to it online? Thanks again. Mike
Re: What sensor did I break on wife's '01 Chry T&C
[Re: A12]
#2822794
09/20/20 12:54 AM
09/20/20 12:54 AM
Posts: 21,404 It's a dry heat
gtx6970
It's a dry heat
spark knock / detonation sensor EXTREMELY common for them to be broken IMO, dont worry about it .
[Re: gtx6970]
#2822918
09/20/20 01:48 PM
09/20/20 01:48 PM
A12
N.E. OHIO, USA
THANKS Bill, that's it. I guess there wasn't any real noticeable negatives maybe because my wife and I always use the higher grade fuels? Then again maybe not as our hearing is getting worse with age Thanks again, Mike
[Re: poorboy]
#2823625
09/22/20 01:52 PM
09/22/20 01:52 PM
A12
N.E. OHIO, USA
Thanks again guys. Thinking back and not knowing when it broke there is a situation that nine out of ten times happens at the same spot just getting off of a 70 mph highway exit that I have chased for some time. After about ten or more miles of highway driving we pull off on a slight uphill grade off ramp to a stop sign and make an also slightly uphill grade left turn over the overpass,. The van will hesitate slightly or even badly and only lifting or feathering the throttle will stop the hesitation. Do you think this might be a fault of a broken or bad knock sensor? I checked and the knock sensor is around $62 on average Thanks, Mike
