Cutting cast iron
#2822651
09/19/20 03:53 PM
09/19/20 03:53 PM
Posts: 8,339 fredericksburg,va
cudaman1969
fredericksburg,va
I need a section off of a broken block, can I cut with an oxy-acetaline torch? I would cut a much larger section then grind it down to fit. Can’t get to it with a grinder or saw
Re: Cutting cast iron
[Re: cudaman1969]
#2822656
09/19/20 04:32 PM
09/19/20 04:32 PM
Posts: 10,752 North Dakota
6PakBee
North Dakota
Years ago (a lot of years ago!) I tried cutting a Chevy three speed transmission housing with a gas torch. As I recall, it worked but wasn't pretty. Just throwing this out, have you considered a plasma torch?
[Re: TJP]
#2822715
09/19/20 07:59 PM
09/19/20 07:59 PM
Posts: 4,808 Star Idaho
67vertman
Star Idaho
While you can cut cast iron with a plasma cutter torch, or any torch.it is not the best method to cut cast iron, due to cast poor Iron content. When cutting cast iron, it is best to use a snap cutter, angle grinder, or reciprocating saw.
My Monster are real!
Living within your means makes life pretty easy.
[Re: cudaman1969]
#2822737
09/19/20 09:00 PM
09/19/20 09:00 PM
6PakBee
North Dakota
Maybe something like this? Angle Cutter
[Re: justinp61]
#2822774
09/19/20 10:37 PM
09/19/20 10:37 PM
cudaman1969
fredericksburg,va
I thought of one of those chainsaw type cutters they use in the wrecking yards and rescue trucks too. The piece is right up into the cam area
[Re: cudaman1969]
#2822776
09/19/20 11:03 PM
09/19/20 11:03 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
What kind of block are you trying to fix?
[Re: cudaman1969]
#2822818
09/20/20 08:35 AM
09/20/20 08:35 AM
Posts: 4,755 Moved to N.E. Tennessee
GomangoCuda
If you can find someone who is capable of making this repair then he will know how to cut out the part you need. Note the word if at the beginning of my post. That is going to be a very difficult repair in cast iron. Is this block super rare and unobtainable?
[Re: cudaman1969]
#2822945
09/20/20 03:15 PM
09/20/20 03:15 PM
Posts: 3,505 DFW
mr_340
DFW
I'd avoid cutting grey cast iron with a torch. From my metallurgy classes back in college, I seem to remember something about that converting grey cast iron into brittle white iron. That is why special rods are needed for welding cast iron.
Floyd Lippencott IV
[Re: cudaman1969]
#2823190
09/21/20 09:52 AM
09/21/20 09:52 AM
6PakBee
North Dakota
Boy, that sounds like a block I ran into at one time. Crack in bore, attempted repair with a MIG, other damage. Here are some photos I took before the seller got the block back.
