big block bellhousing #2822475
09/19/20 01:46 AM
09/19/20 01:46 AM
Finland
Hessu Offline OP
Hessu  Offline OP
Finland
What bellhousing can use for 383 big block to A230 transmission. thanks.
Re: big block bellhousing [Re: Hessu] #2822611
09/19/20 01:58 PM
09/19/20 01:58 PM
I believe Mopar made several different bellhousing that would work, some with just the 3 speed bolt pattern and some with both the 3 and 4 speed bolt patterns , as well as some that had only the 4 speed pattern confused shruggy
I looked up one used in 1965 only for 3 speeds (According to Galens manual, not sure if it has both patterns or not confused) The casting number should be 2468450, it is for the 10.5 inch clutch only. It is cast iron. There are several other 3 speed only in his book for the Max Wedge cars in 1962,1963, they are 2402219, aluminum, for 1963 426 Stage 2, 2402221 for 1963 426 M.W aluminum for T85 trans only, 2402683 cast iron for 361 and 383, all with the 10.5 inch clutches only.
IHTHs luck
I think the 230 trans was a medium duty in the BB, the T85 was a one year only also I think. I'm not sure on any of this information as I never have had a BB with
a 3 speed stick tranny shruggy
Re: big block bellhousing [Re: Cab_Burge] #2822659
09/19/20 04:36 PM
09/19/20 04:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I parted out a '70 Newport four-door with a three on the tree and a 383. It used the common 2892513 bellhousing. I can't remember what transmission was behind it.
Re: big block bellhousing [Re: 6PakBee] #2822815
09/20/20 08:11 AM
09/20/20 08:11 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Do you still have the 3 speed transmission from it.
Re: big block bellhousing [Re: 71GTX471] #2822827
09/20/20 09:21 AM
09/20/20 09:21 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I can't remember if I saved it or not. After all it was just a three speed and I was much younger and stupider. Today I would keep it, then....... If I did keep it, finding it would be right up there with the immaculate conception. Sorry.
Re: big block bellhousing [Re: 6PakBee] #2822916
09/20/20 01:38 PM
09/20/20 01:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did it have synchro first gear?
Re: big block bellhousing [Re: John_Kunkel] #2823184
09/21/20 09:32 AM
09/21/20 09:32 AM
Finland
Hessu Offline OP
Hessu  Offline OP
Finland
Any aftermarket bellhousing? How much different 833 bolt circle are than 230?
Re: big block bellhousing [Re: John_Kunkel] #2823187
09/21/20 09:37 AM
09/21/20 09:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
John, I THINK it did but this was about 1974 and the memory is foggy about more things than this that happened at that time!!!
Re: big block bellhousing [Re: Hessu] #2823188
09/21/20 09:41 AM
09/21/20 09:41 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just Google "2892513 bellhousing" and there are numerous pictures of what the multiple patterns look like. As to reproductions, contact Brewers, I think they handled them at one time.
Re: big block bellhousing [Re: Hessu] #2823327
09/21/20 02:57 PM
09/21/20 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of a SB bell with both the 230 and 833 bolt pattern.
Re: big block bellhousing [Re: John_Kunkel] #2824225
09/23/20 05:33 PM
09/23/20 05:33 PM
Finland
Hessu Offline OP
Hessu  Offline OP
Finland
I ask this at brewer`s and got great info. I have trans with 5,125 front retainer dia and no bb bellhousing for that size. In this case fix is change retainer for their new 4.354 size retainer. thanks.
