Holley Guru's......Jet storage
#2821299
09/15/20 09:48 PM
09/15/20 09:48 PM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
What do you guys store all your jets in?
I now have two full holley jet cases and then two more plastic snap cases just to carry all my jets and air bleeds. I have 4 or more of every size from #23-#110....
I need somthing that holds all of them preferably.....What the heck is everyone using or am I the only idiot that carries around a big pile of jets?
Re: Holley Guru's......Jet storage
[Re: Dragula]
#2821320
09/15/20 10:51 PM
09/15/20 10:51 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I would store the ones you won't ever use( probably 75% at least of what you have) and put the others in the Holley jet box To take to the track or have handy at your shop
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: Dragula]
#2821384
09/16/20 08:03 AM
09/16/20 08:03 AM
Posts: 16,936 NC
440Jim
NC
I have 4 or more of every size from #23-#110.... The plastic compartments of the Holley jet case will hold much more than 4 of each jet size. So one of those will hold all the jets. The air bleeds need another case or plastic bin. I suggest putting the jets near your current jet size in one of those threaded aluminum plates and only take that to the track (with one air bleed size change too). Put the cases in your garage for when you need them. Holly 122-220 link $18.
[Re: cudadoug]
#2821386
09/16/20 08:09 AM
09/16/20 08:09 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: sasquatch]
#2821448
09/16/20 10:27 AM
09/16/20 10:27 AM
Posts: 1,894 South Bend
John Brown
South Bend
Think Fishing Tackle boxes........ That's what I use mostly. Got two of them with the jets I use most, along with many of the small pieces that are needed or ones that get dropped. Still have the big Holley box, but I use the divided fishing tackle box much more often. Think they cost only a couple of bucks each. They were leftover display pieces.
[Re: sasquatch]
#2821453
09/16/20 10:33 AM
09/16/20 10:33 AM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Think Fishing Tackle boxes........ What I use. Gaskets, small parts, specific tools, jet boards, All in one place.
[Re: CMcAllister]
#2821460
09/16/20 10:56 AM
09/16/20 10:56 AM
Posts: 19,543 Las Vegas
Al_Alguire
Las Vegas
I use the Holley jet boxes and their bleed boxes. For the larger stuff I use another compartmented plastic container that I label with a label maker whats in each compartment. Mine go up to .172" pin size for jets and bleeds from .023-.080"
[Re: 440Jim]
#2821496
09/16/20 12:07 PM
09/16/20 12:07 PM
Dragula
I have 4 or more of every size from #23-#110.... The plastic compartments of the Holley jet case will hold much more than 4 of each jet size. So one of those will hold all the jets. The air bleeds need another case or plastic bin. I suggest putting the jets near your current jet size in one of those threaded aluminum plates and only take that to the track (with one air bleed size change too). Put the cases in your garage for when you need them. Holly 122-220 link $18. And what about all the Air Bleeds? I tend to race at least 3 different cars, and they all have their own "range" of jets. So I take everything as I do not want to be missing somthing I need. So I am kinda looking for a solution that has more compartments than the Holley jet kit.
[Re: JERICOGTX]
#2821519
09/16/20 12:46 PM
09/16/20 12:46 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Twice a year - end of Spring, beginning of Fall. Easy.
[Re: CMcAllister]
#2821523
09/16/20 12:58 PM
09/16/20 12:58 PM
Posts: 16,640 On the run…
BloFish
On the run…
Twice a year - end of Spring, beginning of Fall. Easy. For the purpose of?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2821526
09/16/20 01:08 PM
09/16/20 01:08 PM
Posts: 4,114 Yes
sixpakdodge
Yes
Twice a year - end of Spring, beginning of Fall. Easy. For the purpose of? Compensating for air density with the different seasons to maintain consistency.
[Re: CMcAllister]
#2821531
09/16/20 01:17 PM
09/16/20 01:17 PM
an8sec70cuda
Twice a year - end of Spring, beginning of Fall. Easy. Add a little fuel when it cools off in the fall. Take it out when it warms back up. Never seen a ton of difference either way really, as long as the motor is happy.
