Mopar Hemi heads #2821226
09/15/20 06:46 PM
09/15/20 06:46 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Just picked these up and would like to know how much potential is in them. Is the bare head the same just different number? What’s a good price for these, never used
Re: Mopar Hemi heads [Re: cudaman1969] #2821390
09/16/20 08:14 AM
09/16/20 08:14 AM
an8sec70cuda Offline
Those are the newer/better Edelbrock castings of the old MP heads. They will flow a little better than the MP heads when ported. I have the older MP heads on my motor that were CNC ported at MCH.
Depending on the rest of the combo, 900+ hp isn't a problem at all out of those heads.
edit...those aren't the same head I don't think. Top looks like the older MP casting like I have. Bottom is the newer version of the same heads cast by Edelbrock for MP. They are slightly different, but I don't think there'd be any real issue using the pair together.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mopar Hemi heads [Re: an8sec70cuda] #2821422
09/16/20 09:48 AM
09/16/20 09:48 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The “M2” is the Ede made head.
I can’t say if that head has any more potential than the earlier head or not.
The main benefit with them is the ootb fit and finish is just nicer.
Re: Mopar Hemi heads [Re: an8sec70cuda] #2821423
09/16/20 09:49 AM
09/16/20 09:49 AM
fredericksburg,va
fredericksburg,va
Thanks for reply, I have a pair of the one with the springs, the bare one was thrown in with the deal (might try to find a matching one). They will go on the 572 (mopar block)
Re: Mopar Hemi heads [Re: cudaman1969] #2821426
09/16/20 09:53 AM
09/16/20 09:53 AM
So. Burlington, Vt.
So. Burlington, Vt.
Re: Mopar Hemi heads [Re: fast68plymouth] #2821438
09/16/20 10:17 AM
09/16/20 10:17 AM
fredericksburg,va
fredericksburg,va
Meant to say all three were in plastic bags so the reason I asked what they were.
Re: Mopar Hemi heads [Re: fast68plymouth] #2821455
09/16/20 10:39 AM
09/16/20 10:39 AM
fredericksburg,va
fredericksburg,va
Now I have to go look at the heads, good read.
Re: Mopar Hemi heads [Re: fast68plymouth] #2821458
09/16/20 10:46 AM
09/16/20 10:46 AM
Seems like I remember MCH saying their CNC ported versions of the Edelbrock casting were about 5-10 cfm better than the older 110-M MP casting. Don't quote me on that though.
I have a pair of the Edelbrock castings on the shelf and they're definitely a nicer set of heads out of the box than my MP castings were.
FWIW...I've been beating on the MP castings since 2006 and no issues w/ valve seats coming out. Probably just jinxed myself, lol.
CHIP
Re: Mopar Hemi heads [Re: cudaman1969] #2821605
09/16/20 03:37 PM
09/16/20 03:37 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by cudaman1969
the bare one was thrown in with the deal (might try to find a matching one)..............
Wish I had noticed this discussion sooner, as I had a brand new, single 110-M head (first one shown) on the shelf for several years.
I sold it to Dwayne W. at Thunder Performance two weeks ago. (It might have changed hands by now, not sure).
Give me a shout if you want to try to track it down and need a phone number.
Rich H.
Esse Quam Videri
Re: Mopar Hemi heads [Re: ZIPPY] #2821698
09/16/20 08:12 PM
09/16/20 08:12 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The M2 casting has a "ramp" added from the intake valve spring pocket up to the valve cover rail. It looks like it would be better for the SS Hemi guys that run the raised intake port (and can't just weld them up due to NHRA rules).
Floyd Lippencott IV
Re: Mopar Hemi heads [Re: mr_340] #2821761
09/17/20 12:47 AM
09/17/20 12:47 AM
fredericksburg,va
fredericksburg,va
They have to use cast iron only
Re: Mopar Hemi heads [Re: cudaman1969] #2821791
09/17/20 06:20 AM
09/17/20 06:20 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I will ask my friend if he has one or two MP Heads new and if he has one head wants to sell it,
1971 HEMI E BODY REGISTRY
Re: Mopar Hemi heads [Re: hemicar1971] #2821811
09/17/20 09:11 AM
09/17/20 09:11 AM
fredericksburg,va
fredericksburg,va
Thankyou
Re: Mopar Hemi heads [Re: cudaman1969] #2821817
09/17/20 09:31 AM
09/17/20 09:31 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Would the 1964 Hemi cars be an exception?
Re: Mopar Hemi heads [Re: 340Cuda] #2821818
09/17/20 09:49 AM
09/17/20 09:49 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The 65 cars would be the exception.
2011 Drag Pak Challenger
Re: Mopar Hemi heads [Re: rickseeman] #2821848
09/17/20 11:49 AM
09/17/20 11:49 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
1964 Hemi Car used Iron K Heads and 1965 used Aluminum K Heads.
Re: Mopar Hemi heads [Re: cudaman1969] #2821857
09/17/20 12:08 PM
09/17/20 12:08 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Aluminum replacements can be used on any legal Super Stock Street Hemi combination in addition to the 1964 Race Hemis. Check the NHRA Stock Car Classification guide.
Re: Mopar Hemi heads [Re: sixpakdodge] #2822069
09/17/20 09:31 PM
09/17/20 09:31 PM
fredericksburg,va
fredericksburg,va
And would be a power loss unless they let the racers up the compression. The 340s are back to the iron head now
Re: Mopar Hemi heads [Re: cudaman1969] #2822109
09/17/20 11:13 PM
09/17/20 11:13 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
No compression, but the aluminum head is allowed an extra 9 cc on the intake, but -6 cc on the exhaust. I have a set on the bench I've been experimenting with. If they don't work well enough on the car, I have a pair of iron backups.
Re: Mopar Hemi heads [Re: sixpakdodge] #2822286
09/18/20 02:50 PM
09/18/20 02:50 PM
fredericksburg,va
fredericksburg,va
That cc allowance will help, and certainly easier to weld and work with. Did NHRA add HP for the aluminum head?
