Page 3 of 3 1 2 3
Re: Valley Pan Inverted [Re: GomangoCuda] #2821172
09/15/20 04:41 PM
09/15/20 04:41 PM
New Jersey, U.S.A.
FuriousMopar1968 Offline OP
New Jersey, U.S.A.
Originally Posted by GomangoCuda
Originally Posted by FuriousMopar1968
Also she’s running single chamber Super 10 Flowmasters, do you think a Crankcase Evac to the header extensions would still build too much pressure? Those are barely even mufflers haha.
no
It’s surprisingly not as loud as you’d think due the c-body sound padding haha but the neighbors probably don’t like me very much... up
1968 Plymouth Fury - 440 Dual Quad Tunnel Ram
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821174
09/15/20 04:49 PM
09/15/20 04:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The issue with the FBO is that it doesn’t have the ability to limit lower than 5200 RPM.
Why would you want a limit lower than that?
I’d have it set to 4000ish RPM as a right foot limiter during break in process haha. Its all to easy to go light years past that just cruising with the low rear it has in it. Going 65mph on the highway on my way to work it would be spinning 3500 RPM, one accidental down shift from partial throttle kickdown and it would scream immediately. I know this current engine is already broken in, but in the worse case of something failing I want to not worry about the next one.
Pertronics 600 rev limiter is for inductive ignitions and is adjustable from 100 to 9900rpm.
Re: Valley Pan Inverted [Re: GomangoCuda] #2821185
09/15/20 05:19 PM
09/15/20 05:19 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Thanks a lot, your helps very appreciated! So just to be sure and as a redundant check before I pull the trigger on buying it, the Pertronix 600 is able to be wired directly into the Orange Box & Distributor ignition circuit and they will play nice together?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821283
09/15/20 09:08 PM
09/15/20 09:08 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i use the msd on 3 of my cars .
i stick in a 3000 chip once a year to test them !
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821638
09/16/20 05:45 PM
09/16/20 05:45 PM
GomangoCuda Offline
GomangoCuda  Offline
According to their website it will work.
https://pertronixbrands.com/products/pertronix-600-digital-rev-limiter
Actually nothing gets wired to the ecu or distributor.
Non-HEI type systems. (FIGURE 1)
1. Attach the BLACK wire to a good engine ground. Make sure to remove
any dirt or paint beforehand.
2. Attach the RED wire to a 12 volt power source controlled by the ignition
switch.
3. Attach the YELLOW wire to the coil’s negative terminal.
4. The ORANGE wire is not used for Non-HEI type systems. Use the provided
end splice to isolate this wire.
5. The WHITE wire is a tachometer output, compatible with most modern
tachometers
Re: Valley Pan Inverted [Re: GomangoCuda] #2821674
09/16/20 07:08 PM
09/16/20 07:08 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Thanks! up
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821722
09/16/20 09:24 PM
09/16/20 09:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The photo of the valley pan reminds me of my cousin. Probably around 1977 or so he had a 69 RR that he blew up a bunch of 383's in. He had bought a junk yard 383 and put it in the car. We couldnt get it to start and he was turning the distributor as I was cranking it. The engine popped, blew the valley pan up and almost blew the valve covers off, they were junk after that LOL.
R.I.P. Wade, I miss you buddy.
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2825434
09/26/20 09:00 PM
09/26/20 09:00 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Small update on the car, I’ve been driving it around and giving out small beatings here and there, so far it’s seems fine. Had a small breaking up ignition issue but that apparently was just the rev limiter having issues with the Orange Box. Thanks again for everyone’s help forgot how much fun it was to drive the old girl. drive
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2825447
09/26/20 09:18 PM
09/26/20 09:18 PM
GomangoCuda Offline
GomangoCuda  Offline
Rev limiters work by NOT firing random cylinders. If you run it up against the limiter it will in fact "break up". You can't use it like a governor or cruise control.
Re: Valley Pan Inverted [Re: GomangoCuda] #2825584
09/27/20 11:08 AM
09/27/20 11:08 AM
New Jersey, U.S.A.
New Jersey, U.S.A.
Gotcha, It was breaking up at about 3000 RPM it was set for 5700 RPM. In the future I’ll eventually just upgrade to a MSL style box and it may work with that.
Page 3 of 3 1 2 3
