If If I change the quench what really happens
#2820668
09/14/20 04:02 PM
09/14/20 04:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I might end up changing the quench height on a build.. what really happens to the performance on a street engine.. I might have to go from .039 to like .080 so my exhaust valve will get proper clearance(other than compression)
Re: If If I change the quench what really happens
[Re: MR_P_BODY]
#2820694
09/14/20 05:15 PM
09/14/20 05:15 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
It might require less timing to prevent detonation. Ages ago I had some friends who both had very similar 360s. One was 10.5:1 with KB pistons and quench was paid attention to. The the other was 9:1 no attention paid to quench. The quench engine was almost a full second faster and could run more timing than the lower compression engine.
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#2820700
09/14/20 05:34 PM
09/14/20 05:34 PM
Posts: 4,206 New York
polyspheric
New York
The mixture in the quench volume will burn, but it may burn too quickly.
Boffin Emeritus
[Re: Bad340fish]
#2820705
09/14/20 05:41 PM
09/14/20 05:41 PM
MR_P_BODY
It might require less timing to prevent detonation. Ages ago I had some friends who both had very similar 360s. One was 10.5:1 with KB pistons and quench was paid attention to. The the other was 9:1 no attention paid to quench. The quench engine was almost a full second faster and could run more timing than the lower compression engine. Good to know.. right now I need to check the exhaust pocket depth to see if I can mill them deeper and still have enough material in there before I can make any decisions.. might be easier to get some other pistons if cheap enough.. I will sonic check them in a day or so
[Re: 340Cuda]
#2820981
09/15/20 10:00 AM
09/15/20 10:00 AM
Posts: 9,429 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Could you maybe find a ex valve with a hair thinner margin and cut the piston a tiny bit like you mentioned?
Just a thought, if you have a wide margin on your ex valve, couldnt you flat off .010 without issue, I know some of the ferrea valves I use have a very very thick margin that could give some room if needed.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2821064
09/15/20 12:53 PM
09/15/20 12:53 PM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Deckaids ago i used a cutter that you put in place of the valve , secure the head to the motor with a couple of bolts and use a drill to cut each piston. It made a mess but grease in the crevice of each piston/ cylinder wall allowed me to clean it up fine. Wow, that must have been 45 years ago now. Crane or Comp or Isky had the cutter, can't recall who.
[Re: gregsdart]
#2821155
09/15/20 03:54 PM
09/15/20 03:54 PM
MR_P_BODY
Deckaids ago i used a cutter that you put in place of the valve , secure the head to the motor with a couple of bolts and use a drill to cut each piston. It made a mess but grease in the crevice of each piston/ cylinder wall allowed me to clean it up fine. Wow, that must have been 45 years ago now. Crane or Comp or Isky had the cutter, can't recall who. I did the same thing years ago but this engine is still on a stand and I can pull the pistons to put on the mill
[Re: gregsdart]
#2821434
09/16/20 10:10 AM
09/16/20 10:10 AM
RapidRobert
Deckaids ago i used a cutter that you put in place of the valve , secure the head to the motor with a couple of bolts and use a drill to cut each piston. It made a mess but grease in the crevice of each piston/ cylinder wall allowed me to clean it up fine. Wow, that must have been 45 years ago now. Crane or Comp or Isky had the cutter, can't recall who. that's what I did, I cut an old cyl head into thirds & got an intake & ex valve that were .100" larger than the valves & glued sandpaper to the faces & used a drill. I put tape around the perimeter on the piston to contain the debris & had the piston at TDC. worked perfect
[Re: gregsdart]
#2821442
09/16/20 10:21 AM
09/16/20 10:21 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Deckaids ago i used a cutter that you put in place of the valve , secure the head to the motor with a couple of bolts and use a drill to cut each piston. It made a mess but grease in the crevice of each piston/ cylinder wall allowed me to clean it up fine. Wow, that must have been 45 years ago now. Crane or Comp or Isky had the cutter, can't recall who. Isky still has them. Isky Valve Pocket Cutter
[Re: HotRodDave]
#2823317
09/21/20 02:40 PM
09/21/20 02:40 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Mike, Years ago I had a 340 my Dad put together for me in a duster. It had 10:1 with very little quench. It would knock like crazy on pump gas.
Shortly after being put together, it ate a flat tappet cam, and all of the metal went in the pistons. Rebuild the motor with another set of flattops, but this time at 12:1 with very tight quench (.035"). That motor would run on 93 octane ALL DAY....
So I'm not sure what your plan is, but I was able to raise compression almost 2 full points, AND have it run better on 93.
[Re: dizuster]
#2823455
09/21/20 09:29 PM
09/21/20 09:29 PM
RapidRobert
Rebuild the motor with another set of flattops, but this time at 12:1 with very tight quench (.035"). That motor would run on 93 octane ALL DAY.... So I'm not sure what your plan is, but I was able to raise compression almost 2 full points, AND have it run better on 93. I'm convinced!
