What's wrong with Stock stamped Big Block Rockers?? #281997
04/08/09 09:56 PM
04/08/09 09:56 PM
Port Alberni, British Columbia
MoparDonny Offline OP
I have never seen any of them fail but I'd like to here your experiences, pros or cons and pics if you have any. The only thing I've seen with any of mine are slightly worn pushrod tips on a couple of them from my 383 that I beat on pretty hard. Now of course, This is with street type setups with no more than 450 hoses and mild hydraulic cams. I know they have limits.
Don.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: MoparDonny] #281998
04/08/09 10:24 PM
04/08/09 10:24 PM
Martin TN
ridin98ci Offline
ridin98ci  Offline
Martin TN
I have been wondering the same thing.....
LOUD AND PROUD!!!
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: ridin98ci] #281999
04/08/09 10:33 PM
04/08/09 10:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not a thing until you start using a lot more than stock spring pressures. Also remember that they have a lot of miles on them. I would at least get a set of new rockers if that is what you want to use. They also are not quite a true 1.5 ratio.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: MoparDonny] #282000
04/08/09 10:44 PM
04/08/09 10:44 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Don.
Stock 69 RR 383 with 63,000 miles?
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: MoparforLife] #282001
04/08/09 10:46 PM
04/08/09 10:46 PM
Mine are about 10 years old with maybe 2000 miles, but hard ones . They were supposed to be HD ones from MP. They look the same as stock ones from a '75 400 that I put on my 440 thats in my car now.
Don.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: 474218] #282002
04/08/09 10:49 PM
04/08/09 10:49 PM
[quote
Were the other ones in trouble too, or just that one?? If you remember.
Don.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: MoparDonny] #282003
04/08/09 10:52 PM
04/08/09 10:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There was a running change in the rocker designed due to....pushrods punching thru the rocker. The MP "HD" rockers are nothing more than the late model upgraded ones.
Don't be the exception.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: Supercuda] #282004
04/08/09 11:08 PM
04/08/09 11:08 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
when i replaced my stock rockers, the hole where the shaft runs through was really badly ovalled effectively negating any preload and drastically reducing lift. i saw .02- .03 improvement when i went to comp promagnums, and i have a worn out 440 so a fresh motor could see ???????
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: MoparDonny] #282005
04/08/09 11:22 PM
04/08/09 11:22 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Don.
Just one. The cause may have been a liquid lock, as it was found when changing a blown head gasket.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: 474218] #282006
04/08/09 11:31 PM
04/08/09 11:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Back in the 70's I replaced a rocker on 5 engines for having a pushrod through it, never had any other problem with those customers engines that I heard about...
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: 1_WILD_RT] #282007
04/09/09 12:23 AM
04/09/09 12:23 AM
United States
STLDuster Offline
STLDuster  Offline
United States
I thought there was an article in one of the mopar magazines a year or two ago where they "spec'ed out" all of the stock style rocker arms. Found the that .99 cent replacements from the autoparts stores where identical to the expensive heavy duty units.
I want to say they checked the material thickness, material hardness (maybe one was heat treated more or less than another), and found that even dimensionally they were all the same.
I will see if I can find that article, It will take a while to go through them though.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: STLDuster] #282008
04/09/09 12:32 AM
04/09/09 12:32 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Was the lift consistent too?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: HealthServices] #282009
04/09/09 08:41 PM
04/09/09 08:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran the stock rockers on our old 383 Dart. I had comp single springs and the MP .484 cam. Drove it like that for 8 years and raced it a few times a year with a best et of 12.31 @ 110. Ron
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: 383man] #282010
04/09/09 09:03 PM
04/09/09 09:03 PM
Selma, Alabama
Dan Henderson Offline
Selma, Alabama
The magazine that this article is in is Mopar Action, February 2008. The article is called, "Let's Rock". It runs from pages 64-71.
2007 Dodge Ram 1500 SWB V-6
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: Dan Henderson] #282011
04/09/09 10:52 PM
04/09/09 10:52 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've always sorta thought they were fine until you get to about .500 lift. It's at about that point where the side to side push effect on the valve really starts to create some friction, and valvetrain wear. Also, they are inconsistant in their ratio's. I've heard that they can vary from 1.3 to 1.5, but generally check in well under 1.5.
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: StealthWedge67] #282012
04/09/09 11:15 PM
04/09/09 11:15 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
If the geometry is right (in other words, not much more than 0.500" or so lift) there's very little sliding/rubbing going on, the tips actually DO roll over the stems.
Any ones you buy today, at any parts store, are actually the "Six Pack" (read: heavy gauge '67-up) design.
If your'e talking a race engine, that's another story. But for something close to stock, they are unbelievable bang for the buck, extraordinarily well deisgned when you really analyze them.
Rick
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: Dan Henderson] #282013
04/10/09 08:19 AM
04/10/09 08:19 AM
United States
STLDuster Offline
STLDuster  Offline
United States
Thank you, I was having a hard time finding my copy of the magazine...
Re: What's wrong with Stock stamped Big Block Rockers?? [Re: STLDuster] #282014
04/10/09 01:39 PM
04/10/09 01:39 PM
Thanks for the replies I'm going to be running an XE284H with .510 lift so the geometry should be fine. I'm gonna pay attention to the Rocker/Valve tip contact pattern when I put the heads on and get it all set up.
My rockers and shafts still look to be in good shape so I'll worry about upgrading them at another date when I have some money. Work's been quite slow lately, just had to put tires on the wife's car, and we have a baby on the way for August. Not even sure if the Challenger will see the road this year now.
Happy Easter weekend!!
Don.
