Stuck in start position...
#2819998
09/12/20 02:57 PM
09/12/20 02:57 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
Attempted to start the Roadrunner today.... warm it etc. While trying to start it stuck in the start position regardless of key position. Had to jump out and pull battery cable. Also continued to try and start with clutch out as well....
Starter relay?? Ignition switch? How to test starter relay...?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Stuck in start position...
[Re: JMCFAN]
#2820018
09/12/20 04:58 PM
09/12/20 04:58 PM
RapidRobert
ign switch would be my first thought (mainly cuz it didn't act up till you switched the key on). regarding the relay pull the yellow wire terminal off of the relay & jump 12V to its male terminal on the relay to crank it then remove the jumper & see if it stops cranking. I'm assuming that it has a clutch pedal ground to make you start it in neutral, that is strange that it too is inop. it would have to be grounding the black wire on the relay (+fire to the yellow wire) for it to be cranking unless the starter relay is stuck closed. keep us posted
[Re: JMCFAN]
#2820028
09/12/20 05:41 PM
09/12/20 05:41 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Go under the hood... And check the lever position for the reverse lockout mechanismEven though likely U removed the linkage mechanism if the lever on the column itself moves upward, the key is locked and can't be removed... Just my $0.02...
[Re: NITROUSN]
#2820035
09/12/20 06:09 PM
09/12/20 06:09 PM
JMCFAN
New Mexico
Being you stated it would crank with the clutch pedal released I assume you have a clutch pedal switch. If correct it is either the relay or starter solenoid. Take the wire that goes to the starter relay off. This would be the smaller wire that goes to the starter. If it still cranks when the battery cable is on then the problem is in the starter. So....Disconnected the from starter to relay...and it would not crank when battery connected. Then....just reconnected it...and did not crank either...and car started and shut off fine. Flaky relay.....?
[Re: JMCFAN]
#2820037
09/12/20 06:20 PM
09/12/20 06:20 PM
JMCFAN
New Mexico
Good source for quality relay??
[Re: JMCFAN]
#2820065
09/12/20 08:20 PM
09/12/20 08:20 PM
RapidRobert
Good source for quality relay?? they're actually a very dependable item. alot of stuff is made overseas now but I bet with any of em from a store that it'll work OK for you
[Re: RapidRobert]
#2820077
09/12/20 08:36 PM
09/12/20 08:36 PM
JMCFAN
New Mexico
Good source for quality relay?? they're actually a very dependable item. alot of stuff is made overseas now but I bet with any of em from a store that it'll work OK for you Picking one up at Napa tomorrow
[Re: Jim_Lusk]
#2820163
09/13/20 09:31 AM
09/13/20 09:31 AM
Posts: 2,496 God's Country Maryland
GODSCOUNTRY340
Look and make sure the two wires at the starter aren't touching each other where they bolt onto the starter.
[Re: JMCFAN]
#2820213
09/13/20 01:04 PM
09/13/20 01:04 PM
Posts: 12,225 Looking for a way out of Middl...
IMGTX
I have had that happen on 3 occasions.
One was a starter solenoid (on the starter) stuck and wouldn't disengage. My Challenger had the ignition switch come apart inside the column and just by bad luck made a connection from the starter wire to the power wire. The third was a Ford, and the relay on the fender got stuck.
[quote] So....Disconnected the from starter to relay...and it would not crank when battery connected. Then....just reconnected it...and did not crank either...and car started and shut off fine. Flaky relay.....?[/ quote]
Could be a starter or relay.
Hope it helps
[Re: Jim_Lusk]
#2820735
09/14/20 07:04 PM
09/14/20 07:04 PM
Posts: 5,749 ohio
ruderunner
ohio
What year car? The clutch switch didn't start till 70.
Angry white pureblood male
[Re: Jim_Lusk]
#2820776
09/14/20 08:30 PM
09/14/20 08:30 PM
JMCFAN
New Mexico
Well changed the relay and all i good so far.. Took a 20 mile drive across town to the only NAPA that showed the manual transmission relay in stock....to find they are miss labeled....the "manual transmission" one did not have the connection for the clutch safety switch...... the auto trans one does... that one was in stock at my location...1 mile away.... Cars with the clutch safety switch use the same relay as an auto. The "manual trans" relay has the "G" terminal grounded to the case of the relay. I'd bypass the clutch safety switch anyway. They're hard on the crankshaft thrust bearing. How could a switch mounted to my clutch pedal be hard on crankshaft thrust bearing?? Its a dumb little spring switch...? 70 RR just trying to go correct and NM.....
[Re: Sniper]
#2820802
09/14/20 09:01 PM
09/14/20 09:01 PM
JMCFAN
New Mexico
Because it forces you to put the clutch in while starting when the thrust bearing has no lube on it. Ah....thks
