disc brakes e-body to b-body? #2819889
09/12/20 07:24 AM
09/12/20 07:24 AM
N.Y.
sixpacksteve Offline OP
N.Y.
will a 76 dodge coronet disc brake setup fit a 71 cuda?
Hell Hath No Fury Like Mine
Re: disc brakes e-body to b-body? [Re: sixpacksteve] #2819924
09/12/20 10:36 AM
09/12/20 10:36 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yes, use the E body ball joints.
Re: disc brakes e-body to b-body? [Re: sixpacksteve] #2819938
09/12/20 11:34 AM
09/12/20 11:34 AM
AndyF Offline
AndyF  Offline
Kind of fits, some of the parts will work, some of them won't. Knuckle should bolt on there as well as the rotor and associated small parts such as bearings, seals, etc. The calipers won't be a good match for the E body so you'll need source calipers. Check the fit on front hung vs. rear hung calipers to see which way works the best.
