Re: Holley Hi Ram intake
[Re: hudsonhornet7x]
#2820123
09/13/20 01:02 AM
09/13/20 01:02 AM
Posts: 114 Katy, TX
Bakaruda
Katy, TX
I had a Sniper intake for my car. It was junk sent it back they sent me a second one same issues. Then I found a dyno test of it car lost 40HP. So my gut would say unless you are boosted don't waste your money.
1969 Barracuda GENIII Hemi 2019 Ram 1500 Laramie
[Re: Bakaruda]
#2820288
09/13/20 05:00 PM
09/13/20 05:00 PM
Posts: 2,255 IL
furious70
IL
seems like a product without a use today except for a couple no limit builds that have been on here? Hi rpm, probably loses a ton of TQ to OEM manifolds, and you have to spend a gob ton to get valve gear that also support the hi rpm?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: A39Coronet]
#2820616
09/14/20 01:52 PM
09/14/20 01:52 PM
Posts: 112 Michigan
ghinmi
They sell a ton of 'em to LS guys and they're very similar platforms as far as parts and potential. No reason why they won't sell a ton of 'em to hemi guys. It's filling a hole that's been missing in the hemi world.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: ghinmi]
#2820686
09/14/20 04:53 PM
09/14/20 04:53 PM
Posts: 935 Deland, Florida
biff426
Deland, Florida
The short Ritter intake is 7 inches to the carb mount surface from the head flange and it has a hard time fitting under anything. I would be curios what the height of this with a carb top is. I'd try it with 2 4s
