Mopar mega. Block #2818375
09/07/20 10:44 PM
09/07/20 10:44 PM
florida dade
cesar perez Offline OP
florida dade
Whats the max bore size for a mega block not a Siamese block
Re: Mopar mega. Block [Re: cesar perez] #2818386
09/07/20 11:36 PM
09/07/20 11:36 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Cesar, assuming you mean Hemi, a megablock means it is siamese bores. If it does not have core shift, it will go 4.500. A regular Hemi block is generally good for 4.310
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Mopar mega. Block [Re: Hemi_Joel] #2818443
09/08/20 09:10 AM
09/08/20 09:10 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
The instruction sheets that shipped with them originally claimed they'd go to 4.600" actually, but I don't know anybody who's tried it.
Re: Mopar mega. Block [Re: 73DAD] #2818448
09/08/20 09:30 AM
09/08/20 09:30 AM
UK
rb446 Offline
rb446  Offline
UK
Ours is on 4.565 sonic checked ok on thrust apart from back cylinders no. 7 & 8 bulkhead side are a bit thin but no probs yet and holds temps well with street driving/racing, but the combo makes max hp @only 6000rpm.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Mopar mega. Block [Re: 73DAD] #2818453
09/08/20 09:45 AM
09/08/20 09:45 AM
an8sec70cuda Offline
I thought the later MP/World "megablocks" were the only ones that claimed they'd go out to 4.600"?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mopar mega. Block [Re: an8sec70cuda] #2818467
09/08/20 10:28 AM
09/08/20 10:28 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
In my response above, I was referring to the pre-World Mopar Hemi blocks.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Mopar mega. Block [Re: Hemi_Joel] #2818494
09/08/20 11:47 AM
09/08/20 11:47 AM
central il.
second 70 Offline
second 70  Offline
central il.
There were 2 different mega blocks 1 was a siamese the other wasn't. The siamese has mopar cast in the block above the 2468330. As you can see 4.31 is the max recommended bore for the full water jacket block.
Mike
Re: Mopar mega. Block [Re: second 70] #2818525
09/08/20 12:48 PM
09/08/20 12:48 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Fwiw I have a full water jacket block and there's a sticker on the bellhousing area that says 4.34 max bore.
Maybe best to just have it sonic checked.
Re: Mopar mega. Block [Re: INTMD8] #2818806
09/09/20 04:49 AM
09/09/20 04:49 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Just for Info, we had a 4.50 bore 528, using an early # 625. The block had a crack in the external water jacket nr the starter. We got it repaired but we still always had to run it with block / rad sealer. Doing a little bit of digging I heard there was a few out there like that. Anyway, we got a replacement block sent over to the UK FOC after my wife managed to get hold of Dave Hakims email address,that one was a #624. We ran the 528 for years and it's still going with another owner but then we wanted to go 572. We dug the #624 out, it was sonic checked, there was no way it would safely go out to 4.50". We ended up with a KB block.
