Rear sway bar with leaf springs moved in #2817653
09/05/20 11:17 PM
09/05/20 11:17 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
This would be 1970 E body.
If you go with a 1-inch inboard spring relocation, can you then use a B body rear sway bar ?
Re: Rear sway bar with leaf springs moved in [Re: hemienvy] #2817727
09/06/20 10:26 AM
09/06/20 10:26 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
following. i've got the same question.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Rear sway bar with leaf springs moved in [Re: hemienvy] #2817732
09/06/20 10:39 AM
09/06/20 10:39 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
No, for several reasons. Frame rails are in different positions. Additionally, the only factory style rear sway bars in '70 earlier B body cars where you are sourcing that housing were police units, which are as rare as hens teeth and not reproduced anywhere. I'm not even sure if these police units mounted on the frame rails, for that matter.
A '71 and newer rear bar defeats the whole purpose of narrower as those housings were wider and mounted under the housing.
If you have a stock mount E body sway bar, you can create a 1" offset link or have the arms bent in to align with the OEM mount plates.
All aftermarket rear sway bars, except for Firm Feel's OEM bar, mount under the axle where it doesn't matter on exact axle width.
Re: Rear sway bar with leaf springs moved in [Re: TC@HP2] #2817748
09/06/20 11:18 AM
09/06/20 11:18 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Re: Rear sway bar with leaf springs moved in [Re: hemienvy] #2817755
09/06/20 11:26 AM
09/06/20 11:26 AM
AndyF Offline
AndyF  Offline
Just have a semi-custom sway bar built for the car.
Re: Rear sway bar with leaf springs moved in [Re: AndyF] #2818185
09/07/20 02:38 PM
09/07/20 02:38 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hmmmmmmm.
Good info, thanks fellers.
Re: Rear sway bar with leaf springs moved in [Re: hemienvy] #2818192
09/07/20 02:55 PM
09/07/20 02:55 PM
moparx Offline
moparx  Offline
i have bent several bars cold, using nothing more than solid clamping and holding practices, plus a long piece of pipe.
they are not that hard to bend this way, but be very careful of anything slipping or coming unclamped.
beer
Re: Rear sway bar with leaf springs moved in [Re: moparx] #2819709
09/11/20 03:03 PM
09/11/20 03:03 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've seen it done 3 different ways.
1. Bend the ends of the bar in to line up with the perch mounts new location.
2. Custom offset end links to line up with the perch mounts new location.
3. Modify the perch mount to move the mounting point back out to the factory width.(stock end links can then be used)
Re: Rear sway bar with leaf springs moved in [Re: hemienvy] #2824028
09/23/20 12:16 PM
09/23/20 12:16 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Remove the rear sway bar, you don't need it. The `Cuda handled much better at the track without one, more stable. Saves weight as well!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
