Mini Starter on 1961 318 Poly? #2815267
08/30/20 10:13 PM
08/30/20 10:13 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Guys, I've been told it's doable, just like to hear from those that run a mini starter on a 318 Poly, any issues? or things to avoid? adapters needed?
TIA,
Mike
Re: Mini Starter on 1961 318 Poly? [Re: DAYCLONA] #2815313
08/31/20 01:46 AM
08/31/20 01:46 AM
Me thinks you've been told wrong tsk The starter ring gear is a lot further away from the back of the block than the 1962 and later cars are with all aluminum 727 and stick shift flywheels scope
Re: Mini Starter on 1961 318 Poly? [Re: Cab_Burge] #2815326
08/31/20 05:51 AM
08/31/20 05:51 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
A lot of info floating around on various sites, but nothing concrete regarding the bell housing/starter bolt configuration/tooth count/etc/etc adapting a mini, I can get a custom built reduction starter for the poly to replace the direct drive boat anchor, but I'd prefer a mini, I've run across a few threads of guys modifying minis to fit, but only on the 1st gen HEMIs and 361-413... the 318 poly seems left out, plus a lot of one year changes in late 50's/60/61 on the polys.... the Forward Look forum is a little baffled on modern upgrades, and besides those guys are kinda locked into "originality", if there's a post over there on 61 318 Polys running minis, I can't find it, hoping someone here has done an actual fitment?....
Mike
Re: Mini Starter on 1961 318 Poly? [Re: DAYCLONA] #2815341
08/31/20 07:41 AM
08/31/20 07:41 AM
E
earlymopar Offline
earlymopar  Offline
E
I'm running one on my 65 Poly. However, I'm not running a factory bell housing so I'm not aware of any issues with the original. I'm using a late 60's aluminum 340 bell housing.
Re: Mini Starter on 1961 318 Poly? [Re: DAYCLONA] #2815343
08/31/20 07:45 AM
08/31/20 07:45 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Did you ask the question over there at forward look? Lots of Guys there that modify things.
Look in members rides and you can see plenty of swapping and modifying happening over there.
Re: Mini Starter on 1961 318 Poly? [Re: NANKET] #2815369
08/31/20 09:17 AM
08/31/20 09:17 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
I think if I ask, I'll see some of the same answers/confusion/misinformation from previous threads in the search/archives there, guys on Moparts are a little more in tune with modifying things....
Re: Mini Starter on 1961 318 Poly? [Re: DAYCLONA] #2815461
08/31/20 12:08 PM
08/31/20 12:08 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The pre-'62 starter mounting is way different. There are aftermarket mini-starters for some pre-'62.
https://www.qualitypowerauto.com/catalog.php?item=600
Re: Mini Starter on 1961 318 Poly? [Re: John_Kunkel] #2815467
08/31/20 12:17 PM
08/31/20 12:17 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks John, I saw you mention this over at Forward Look when I was searching the various post, a little spendy at $300 which I don't mind, but if there's a more readily available/common source that's adaptable, I'd rather go that route, my luck I buy the specialty item, and it goes disco if I need another years down the road, or no one wants to service it
Mike
Re: Mini Starter on 1961 318 Poly? [Re: DAYCLONA] #2815491
08/31/20 12:48 PM
08/31/20 12:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you don’t ask, you won’t receive any info. Ask a specific question and state what transmission you have, I’m pretty certain there are people there who know your answer. If you don’t ask and sift through the useless answers you’ll just be stuck here asking the wrong group.
As we well know there is a large part of the hobby that has to have a mini starter in everything and they can’t stand a 1962 and up gear reduction starter and refuse to use them, and they actually work. Those 1961 starters are not anywhere near as good as a gear reduction. So guys over there know where to buy them.
You are talking about the group of people that have to post some answer even though they don’t know what the heck they are talking about. We have seen them on moparts, they are everywhere.
Re: Mini Starter on 1961 318 Poly? [Re: NANKET] #2815693
08/31/20 09:58 PM
08/31/20 09:58 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
I agree, when/if the time comes and I don't have a course of action I find favorable, I'll post a Q on the Forward forum, the last time I posted a question on the Forward forum, the responses are just like any forum response, lots of guesses, misinformation, etc, etc, eventually there's always someone that can help...I like to explore all avenues whether I search on my own or in rare cases ask for assistance
Mike
